Help! wifes gonna kille me..How do you get overspray off a car!
Discussion in 'The Hokey Ass Message Board' started by dannyego, Aug 15, 2009.
  1. dannyego
    dannyego
    I was painting some stuff(rattle can) in my garage and got some overspary on my wifes new car. She gets back in town tommorow and I need to pull a ferris bueller and fix it before she finds out. any ideas would be appreciated!
  2. zzford
    zzford
    Usually turpentine will take rattle can paint right off. Be sure to wax the affected areas afterwards.
  3. compound or cleaner wax and elbow grease (and a prayer).
  4. mazdaslam
    mazdaslam
    A clay bar should work.
  5. Hubbcat
    Hubbcat
    from Sweden
    use only a good wax,gona take the promblem away.
  6. $$$$ --- More Paint !!! sorry >>>>.
  7. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Taake it out and get it detailed.No time factored.You can even tell her you sent the car out and got it detailed. She will appreciate that you cared.I should write a book.And you might get laid
  8. bonesy
    bonesy
    Clay bar should do it no problem.
  9. Jack
    Jack
    from Austin Tx
    Same thing happened to me. Clay bar took it right off. Be sure to wax afterwords though.
  10. Clay bar it if it's a new car. Or take it to a detail shop for a polish. Then you can surprise her with a freshly detailed car.
  11. dannyego
    dannyego
    Thanks guys, Im going to try the clay bar tonight. If all else fails Ill drop it off at a detailer on Monday on my way to work.
  12. ltex old iron
    ltex old iron
    b-12 carb cleaner..ive used it pleny of times on several things..it takes only the spray paint off and doesnt damage the cars paint..ive done it several times on the same spot even and only did what i wanted it to do
  13. L110Mike
    L110Mike
    from North OC
    This might work for you, it worked for me with 1-shot 2 days ago.
    supplies:
    Easy Off oven cleaner (yellow can, about $5)
    paper towels
    plastic bags
    masking tape
    rubber gloves
    clean rag
    directions:
    tape off any plastic/rubber areas that may absorb the spray.
    spray the affected area, and then place a paper towel on top. spray the paper towel on top of the area.
    take the plastic bags and tape it over the paper towel
    wait 10-15 minutes
    wipe away with a clean rag.
    repeat as necessary and buff it out.
    i know it works for removing 1-shot, so you may try it with your over spray. remember to use gloves, i wish i did, my fingertips are all nasty now.
  14. dickster27
    dickster27
    from Texas
    Holy bejesus, it's just a bit of overspray. Good grief, all you have to do is to spray some WD40 on a rag and dab it on the overspray, wait a few minutes and just rup it off. You don't even have to rewax as the spot will more than likely be shinier than the rest of the car. KISS>>>>>>>>>>>>>>>>>
  15. cm30
    cm30
    clay bar works I did the same thing to my wifes car.You have to wax it after.
    good luck
  16. 2manyprojects
    2manyprojects
    W D 40 would be my choice, you did say it was just over spray!!!
    Not A what the F was I think in I painted the wrong thing:eek::eek:
  17. zman
    zman
    from Garner, NC
    ^^^^^^ what he said.
  18. lowrodderDon
    lowrodderDon
    Did it too, only it was my Camaro, claybar fixed it right up. Good luck
  19. DMFB
    DMFB
    This guy nailed it. I'm not even remotely trying to sound like a ****, but if you need to ask this question, I'm ***uming you are not familiar with compound or clay bars. Either of those will fix you up......If you are short on the cash and can't swing the detail shop, use the claybar....because I'm also ***uming you don't do too much high speed buffing. Anyway, best bet is to pop out the 100 bucks and get it the car lookin spiffy. She'll think you're amazing, and prolly return the thanks by ***ual favors. Hell, you even might get a steak dinner out of it. It's a win win brother.
  20. Duece's wild
    Duece's wild
    Your not going to believe this, I learned this from an upholstery guy. Take a rag (do this outside) put a small amount of Gasoline on it, and rub it out. Then wash and wax. Get the doghouse ready.
  21. RodStRace
    RodStRace
    Yep, you can make it a lot worse yourself, and since you asked, that is more likely than not.
    Pay for the detail, it will make you remember the next time you pop the top on a spray bomb.......
  22. sixfink
    sixfink
    from Germany
    paint is just a colorful coating to prevent corrosion, right?
    A rag lightly saturated with acetone will quickly remove rattlecan overspray, then. BTDT.
    If the paint underneath the overspray won't hold up against acetone, it wasn't worth a dime anyways. It's simple like that, coming down to Darwin once more. Survival of the fittest.
  23. racer756
    racer756
    Best answer ..
    BTW, Dave Ramsey loves your Hot Rod, as long as Its not financed.:D
  24. publicenemy1925
    publicenemy1925
    from OKC, OK
    I use lacquer thinner on a rag, but the clay bar works wonders.
  25. 29bowtie
    29bowtie
    The Detail shop, is going to use the clay bar, so why can't you?:eek: It ain't rocket science.:rolleyes:
  26. 23 bucket-t
    23 bucket-t
    Your screwed, no matter how clean you get it she will know. When it come to cleaning something, it is never good enough in a woman's eyes. Believe me I know.
  27. Bigchuck
    Bigchuck
    from Austin, TX
    Cripes man, what kinda women are you all married to that you have to sneak around and /or lie to about this kinda stuff?
  28. doozcoupe
    doozcoupe
    WD 40 or mineral spirits. The other solvents might be kinda iffy if there was paint repair work done at the factory or dealer.
  29. skullhat
    skullhat
    just about anything will take off fresh spray can overspray.
    in your case you are probably best off with the wd 40 method and a quick rewax.
    the clay bar works excellent, i use them all the time, but they are around 40 samolies, plus you need the lube for it
    skull
  30. I stripped the paint off 55 gallon drums using Easy Off....... DO NOT get that **** on your wifes car!
