i am getting an original sharp 3 carb intake with a trio of 97's from a close friend for my 50 shoebox. my question is the engine is otherwise stock will this be able to be tuned to work on a stock motor? i see speedway sells a block off plate to block the center carb would that be better as i have read that 2 carbs work better on the street. thanks in advance
You'll be fine. Set them up progressively ,so they don't just all open at once. 97's are finiky. Unless your running the stock fuel pump, put a pressure regulator before the fuel block and keep pressure down to about 3 or 4 PSI at the Carbs
i read somewhere that it should be set at 2 1/2 psi that seems really low to me. and thats also what i thought i will set them up progressive not all at once.
Fuel pressure, 2 1/2 to 3 psi max..Progressive should work fine..shut the air/fuel mixing screws on the secondaries. Duane.
I've got a 2x2 with 97's in my '50 Ford. I did alot of reading about the stock fuel pump, pressure regulators, etc. when I set it up. I read (most likely here) that if you raise the stock fuel pump up it shortens the pump stroke and lowers the pressure. To raise it up, rather than using a stock fuel pump gasket, use 2 or 3 of the water neck gaskets. They fit just fine and are thicker. That's what I did on mine. I don't have a fuel pressure gauge so I don't know if it actually worked BUT my carbs don't leak so I'm happy with it
just make sure you float that 94 my way! ive already got one for the 31 but always willing to use more
hey buddy found me here too this is my other home other than ratrodbikes. anyways i have another 94 holley in the trunk that is taken apart if u want it then its yours. but this setup is mine lol. cant wait to get the carbs rebuilt, straight pipe the exhuase and such.
is it necessary to change the throttle plates on the secondaries, to keep any air from leaking past when the are supposed to be shut?
If I can run 3 97s on my Flathead 6 and its just mildly worked, I think you should be fine. But running progressively is your best bet. A old timer I hang out with has three 97s on his flathead in his 47 Ford and it runs great. Just tune them right.
The 3's will look way cool but I wouldn't run all 3 myself, I would run 2 of them and dummy the middle one to look like it is functional but no gas feed. The 2 carbs will be more than enough for powering your motor and with the price of gas nowadays it is really just a waste of money to run 3 or more unless you are into using the power regularly. Just MHO. There is a ton of info on multi-carb tuning and linkage available.
Silent Rick..You can. I hold the base up to the light and see if any light comes through around the throttle plates..It's really hard to get them perfect. What I've found is trying different throttle plates, they seem to be different in size. You can also, silver solder the plates and machine to fit.. Duane.
How would running the outside two carbs with none progressive linkage be better a better mileage setup that three carbs being ran progressive? I have 3 97's on a sbc, they are ran at 2.5 psi of pressure and work great. As far as the outside carbs, the idle screws are in all the way and the ****erflies need to be closed otherwise, you will be running air thru them with no fuel and it will be lean and probably give some idle issues.
31ACoupe..Gotta be carefull about the plenum area in the intake. The air/fuel needs to flow to feed the runners of the center cylinders..If it's an open plenum intake it will work with the two outside ones "BUT" I would run the 3x2 with progressive linkage.. Duane.
i am also getting a 2 carb intake not sure who made it yet. i agree that might work better just about everyone i have talked to says since i plan to leave the motor mostly stock stick with 2 carbs
