Narrow Radials versus Bias Ply on 37 Ford
Discussion in 'The Hokey Ass Message Board' started by jonnyzepp, Aug 17, 2009.
  1. jonnyzepp
    jonnyzepp
    I've got a 1937 Ford, 59AB with 3peed, original rear and 1940 Ford brakes. I've got some old 15" steel/chrome wheels on it with radials. Got those cheap. I'd like to go to 15" Ford steel wheels, hub caps, trim rings and narrow tires. I like the look of the original style bias ply tires but my buddy, who's more into muscle cars, says to go with radials. He says the ride is too rough with bias ply and they will get flat spots. I know they have narrow radials but they are more expensive. I'm looking for some recommendations and advice. Thanks for the help.
  2. metal man
    metal man
    Radials last longer , are cheaper , and go straighter . I'm ***uming (hoping) you've got fenders on the '37 ... use radials , no brainer .
  3. X38
    X38
    The Coker Cl***ic seems to get the thumbs up (5.5, 6.5. & 7.5 I think) but unfortunately is only available in 16". Beyond them, the rest look like well, radials. Depends if you're OK with that.
  4. Arthur1958
    Arthur1958
    I know what you mean. I still have some bias-ply tires on old wheels in the shop, basically just garage art now. They did look cool, but they were terribly inferior tires. If you intend to drive your '37 much, you should compromise and run radials.
  5. jonnyzepp
    jonnyzepp
    Thanks for the input. It's greatly appreciated.
  6. Garry Carter
    Garry Carter
    I'm running the Coker Cl***ic radials ... and they come in fairly narrow widths. Couldn't be happier with how they handle, although I'm only a few thousand miles into the trip.
