15" Ford Wheels Factory Pin Stripes
Discussion in 'The Hokey Ass Message Board' started by Little Wing, Aug 19, 2009.
  1. Little Wing
    Little Wing
    from Northeast
    Did the 49-51 Lincoln 15x6 or the 49-64 Truck wheels come with the 3 pinstripes like the older 16 " wheels did?
    Trying to find match for these,,also what was the name of this Maroon / Burgundy color.
  2. rollie
    rollie
    I've got a lot of measurements taken from original striping on wheels from the past 33 years. I know 49-50 Chevs did but I don't think the Fords did . I think they stopped in 48
  3. Bill Van Dyke
    Bill Van Dyke
    If memory serves me..I think Ford stopped striping wheels after the war. Bruce??
  4. milorat
    milorat
    I bought 4 -15"x5" with Merc caps and rings that look just like yours this past winter at a swap meet. I can't tell if they are brown or purple because I'mm color blind. No, they are not for sale.....
  5. Little Wing
    Little Wing
    from Northeast
  6. Bill Van Dyke
    Bill Van Dyke
    the maroon that was used on early ford wheels was mandarin maroon. Those wheels with inside cap nubs were used until '48 then they went to outside nubs in '50 on. Ford and Merc both. Trucks too. Hard to tell from the pic what color you have. By the way, a few wheel aftermarket folks offer that wheel. The styling key is the open vents vs. solid.
  7. Little Wing
    Little Wing
    from Northeast
    yeah ,,I know,,thing is trying to match these age wise :( not gonna be easy I'm sure
    Thanks for the color info
  8. Bill Van Dyke
    Bill Van Dyke
    What do you mean "age wise"? Are you trying to find a match with the same color/stripes? If they are 16" it may not be too hard. Good luck.
  9. blitz
    blitz
    i know this is no help but are those the wheels with marker on them. if so how did you get it off
  10. Little Wing
    Little Wing
    from Northeast
    Yes the are and SOS pad,,, though I did the whole wheel and not just 1 spot so everything was kinda uniform,,,was to worried with the chemical ideas that I would end up with some kinda stain spot that I would never be able to get out. I did circular motion as well as I was told that is the way to do it ,,not just back and forth..
    Bill age wise I mean the look these are 16's but I need to find 15 that will be close,,I know thats a tall order but ,,:)
  11. SASROD
    SASROD
    This is a 15 x 5 wheel I have. it looks like its the same color as your wheels, but its missing most of the paint. The pin stripes are a little further out. Its stamped Ford between the lugs on the front, and Kelsey Hayes inside partially covered by a rivet.
  12. Little Wing
    Little Wing
    from Northeast
    Do you have a pair of them :D is that still a 5 on 5 1/2 bolt pattern ?
  13. SASROD
    SASROD
    Just have the one and it is 5 on 5 1/2 bolt pattern.
