Please teach me Flathead Aluminum heads
Discussion in 'The Hokey Ass Message Board' started by HOTRODSWE, Aug 20, 2009.
  1. HOTRODSWE
    HOTRODSWE
    Hi all
    What brand of Aftermarket aluminium heads for a 59ab will fit with stock studs? I don,t want to change them
  2. doctorZ
    doctorZ
  3. BangerMatt
    BangerMatt
    You SHOULD change them.
  4. HotRodJosh
    HotRodJosh
  5. lowsquire
    lowsquire
    from Austin, TX
    As far as I know most ,if not all,aftermarket heads require longer bottom row studs..Its not that big a deal..Buy a stud extracting socket and rip em out.
  6. HOTRODSWE
    HOTRODSWE
    Ok I get the point, but could anyone answer if there is any heads that goes with stock studs? I heard Navarro, Edmunds, Evan, but not sure if it,s true
  7. pasadenahotrod
    pasadenahotrod
    from Texas
    The selling point of most early production speed heads was instant installation so they had the pockets sunk into the stud locations just like factory iron heads.
    Later, much much later, heads started being made with flat decks using all the same size studs which picked up considerable extra water capacity for better and more even cooling.
    All modern speed heads have this feature, most even though branded with different names appear to have only the length, placement, height and thickness of the cooling fins as distinguishing feature.
  8. Bruce Lancaster
    Bruce Lancaster
    Don't know much about current heads, but I think Edelbrock still makes late heads with stock stud lengths. Edelbrock used to make S series (take stock studs) and R series (all long studs) heads for earlies in Block letter days and in script, and there were many other suppliers as well. Also, if looking at head measure the depths of the bosses on your stock heads on the two sizes of shorter stud holes and use those to compare...it looks to me that some of the apparently stock-stud heads were not thought through very well, and did not allow enough room for the very necessary washers, so you either run inadequately engaged nuts or order custom studs anyway...
  9. Defisch
    Defisch
    from Hudson FL.
    I'm runnin Edmunds on my 48' with stock studs.
  10. HOTRODSWE
    HOTRODSWE
    Thanks for info, anyone knows there to get Navarro heads? are they reproduced?
  11. brigrat
    brigrat
    from Wa.St.
    As already stated H&H Flatheads ...............
  12. weemark
    weemark
    from scotland
    ive got original navarro heads on my 59ab and they dont fit with original studs.
    here is a pic of my engine.
  13. captainjunk#2
    captainjunk#2
    weemark that engine is awesome eyecandy
  14. 36tbird
    36tbird
    Dude, your pedals are on the wrong side!:D
    Where is that straight oil filler tube and base from?
  15. flathead lugnut
    flathead lugnut
    from seattle
    very nice engine.. Whats that fan and pully from. been looking for somethin like that
  16. weemark
    weemark
    from scotland
    the pedals are on the right side, its yours that are on the wrong side ;) the filler tube came from flathead jack http://flatheadjack.com/38.html
    the fan is a std 6 bladed flathead fan from something like a '39 ford, the pulley was made up for my application as nothing else was going to fit in there. the bracket for the generator was modified and a mount for the fan was welded onto the genny bracket then shaped as needed, its still to be finished off and polished.
  17. srosa707
    srosa707
    from Sacramento
    Its not fun to pull the studs. I broke 3 pulling mine, and stopped! Still running original studs.
  18. 1950Effie
    1950Effie
    from no where
    Change the studs. Their torqued and retorqued over the years. They stretch and just aren't reliable after all those years. Bolts or studs your choice. Most heads will except either or. But Pasedena is spot on. Almost of the originals were designed to be direct bolts ons. H&H, Shadow Rods, Reds Headers all good sources and there are many more.
