Help fixing 64 riv's brakes
Discussion in 'The Hokey Ass Message Board' started by Shiva69, Oct 18, 2003.
  1. Shiva69
    Shiva69
    i need help fixing the brakes on the 64 riv. there isn't any pop back with the pedal and i checked the brake fluid level and it seems to be full. The diaphram on the inside of the cover was pulled in.
    please give me some help here so i can drive it a bit.
    And thanks for the advice for starting her up. She started beautifully once we finally got gas to the carb. She has new gas now and usually starts the first time. and she sounds great minus a miss on the p***enger side. I'll pull the plugs as soon as i get her in her storage garage.
    Thanks
    Garth
  2. mrrocket
    mrrocket
    need more info man....doesi t have pressure? Is the boot "distorted", have you bled the system? Give us more info!!!!
  3. Pop back? New term to me.
    Stays on the floor when depressed or what?
    Any resistance when depressed?
  4. Shiva69
    Shiva69
    The system hasn't been bled. It was used this past april and the brakes were ok then.
    There is resistance when the pedal gets pushed to the floor but it dosen't return by itself one needs to pull it off the floor with ones toe.
    I might need to edit my response because i forgot to answer something
    Garth
  5. Shiva69
    Shiva69
    bump?
    please?
    help?
    Me?
  6. Kustm52
    Kustm52
    Could be the booster....or just crud in the m/c. I have a '64 LeSabre wagon that was the same way...after a few days of driving it cleared up. Just remember to have your other toe hooked under the pedal when braking...or it will suprise you! I think it would work itself out...if not pull the m/c and check it.
    I've got several '63 - '64 RIvs if you need any parts...
    Brian
  7. Shiva69
    Shiva69
    Alright i'll go see if moving around will take care of it.
    I'll mark you down as having parts. I still need to do a full inventory of what the guy has. But right now i am working soo much...(makes me glad the guys a good friend)
    Thanks
    Garth
  8. Kustm52
    Kustm52
    It was worth replying but it was worth it just to see the girl on the left there....
    Brian
  9. Shiva69
    Shiva69
    lol... thats why i like posting...
    Garth
