Need a Manual trans for a Flathead Lincoln
Discussion in 'The Hokey Ass Message Board' started by oldiron73, Aug 23, 2009.
  1. oldiron73
    oldiron73
    from WISCONSIN
    I am in need of a manual trans for a 1949 to 1951 Lincoln Flathead V8.
    Let me know if anyone has a decent one for sale.
    Thanks Mark.......Oldiron73.
  2. Dale Fairfax
    Dale Fairfax
    The standard transmission in the '49-'51 Lincoln was the B-W T-85 with the R-11 overdrive. This was a step up (Heavy duty) from the T-86/R-10 used in the '49-'54 Fords and Mercs. The Fords and Mercs began using the heavier units in '55(?)/ '56. If you can locate one from those later Fords & Mercs up thru whenever they stopped offering O.D. you should be in business. I have two but I'm not in a position to offer either since I've not inspected them to determine which one to shed.
  3. oldiron73
    oldiron73
    from WISCONSIN
    Keep me posted if you come across any other transmissions.
    I have a 1951 Ford F1 I am putting this in.
  4. junkyardjeff
    junkyardjeff
    Do you have a bellhousing and clutch parts for it as the 49 to 51 big trucks used those motors and would be a source for those parts.
  5. HR Classic Cars
    HR Classic Cars
    from Wylie, TX
    putting a similar engine, a 1956 V12, into my 1950 F1, but planning on using the truck 4 speed behind it.
    I've got the Lincoln trans + OD unit for sale if you are interested.
  6. Dale Fairfax
    Dale Fairfax
    '56 V-12 ??? Last Lincoln V-12 was '48.
  7. oldiron73
    oldiron73
    from WISCONSIN
    Rob,
    I am interested in it.
    What condition is it in, was it working when pulled.
    How much do you want for it.
    Thanks Mark.......
  8. oldiron73
    oldiron73
    from WISCONSIN
    I do have the bellhousing and clutch for it.
