engine question
Discussion in 'The Hokey Ass Message Board' started by rockogrease, Aug 25, 2009.
  1. rockogrease
    rockogrease
    from So. Cal
    on a 235 cid in a chevy truck,
    it stutters and hessitates at semi-high to high rpm in 3rd but not at all in 1st or 2nd
    i have the twist distributor and a 1bcarb
    any ideas? need more info to get an idea?
  2. squirrel
    fuel starvation?
    had one with a kinked hose under the cab where the tank line connects to the line going forward....also the sock in the tank (if it's still there) could be plugged
  3. rockogrease
    rockogrease
    from So. Cal
    that doesnt make sence to me because even at HIGH and i mean high rpm in 1st and second its ok but at cruizing (hyway speed) it sputters and pops that doesnt make sence does it?
    i cant inspect the vehicle im at work.
  4. squirrel
    high rpm in low gear is probably not full throttle, eh? takes a while for the carb to drain, then it'll act up.
    I've encountered fuel starvation problems, they generally only show up at highway speed in high gear (or in lower gear at full throttle).
    Another possiblity is the wire from the dist to the coil being frayed/loose/shorting. Had that happen too, the 235 vacuum advance rotates the whole distributor, so the wire moves around.
  5. hydroshawn
    hydroshawn
    from Tx,Ca
    I ran a gl*** fuel bowl with filter right at the carb and electric fuel pump with reg.
    Runs like a top & purrrrs like kitten
  6. rockogrease
    rockogrease
    from So. Cal
    now the wire sounds like that could do it, i might just have t chech that out when i get off lol
  7. hydroshawn
    hydroshawn
    from Tx,Ca
    that could be possible too but I had the plug wire at the coil though, it was not in the hole at the top just barely in the rub grommet.
    gotta watch out for them gremlins
  8. wildearp
    wildearp
    from tucson, az
    Bad points will act like a fuel system problem. A bad condenser will do the same. I have learned this the hard way a couple times. Even a new condenser can be bad if the wire is crimped to the capacitor lead. You won't see it, but definately use Blue Streak or something else of high quality.
  9. squirrel
    There are many causes for those symptoms...and it's usually hard to figure out just which it is. could be a bad coil, dist cap, wiring, switch, resistor, as well as lots of things in the fuel system. The key is that it's a problem that happens under load, so something is working most of the time, but not as well as it should be.
  10. I vote ignition !! >>>>.
  11. squirrel
    93% of carburetor problems are caused by the ignition system....
