ford 8 inch question
Discussion in 'The Hokey Ass Message Board' started by goldflake, Aug 26, 2009.
  1. goldflake
    goldflake
    Well I was mocking up my triangulated 4 bar rear set up and I mesured one side and then the other side of the axle and found that one side of the diff was linger than the other. the location I welded the top part of the 4 bar were at differant location, but the rear end is still plum...just wandring if that is normal...thanks
  2. 48fordnut
    48fordnut
    pinion is not centered, normal
  3. Drive Em
    Drive Em
    Actually the pinion is centered, hence the housing is offset. All 8" rear ends have centered pinions and offset housings.
  4. goldflake
    goldflake
    ok so the hinge points for the triangulated 4 bar at not in the same spot on the sides of the pumpkin,,,,,
  5. Drive Em
    Drive Em
    Correct, they should be centered on the housing itself, but not in relation to the pumpkin.
  6. goldflake
    goldflake
    I found the center of the housing wne from that point...just looks weird
  7. Drilled
    Drilled
    from Colorado
    Below is my Ford 8" with Pete & Jakes Triangulated 4 Bar.
  8. krooser
    krooser
    Always looks "off" when the pinion is centered but the pumpkin isn't.
