9" Ford jackpot question
Discussion in 'The Hokey Ass Message Board' started by 41hemi, Aug 27, 2009.
  1. 41hemi
    41hemi
    A friend just removed a jackpot from a late 70's lincoln and it has an electrical connection/sensor on the side of the housing up by the front pinion bearing. We are curious what this is for. Any 9" experts out there that can answer this for us?
  2. flying clutchman
    flying clutchman
  3. Traction control? senses sudden acceleration of the pinion?
  4. forddragracer
    forddragracer
    speed sensor for cruise control, i'm thinking
  5. Relic Stew
    Relic Stew
    from Wisconsin
    That's for the Sure-Track, an early attempt at anti-lock brakes. Became available in 1970.
  6. 1950Effie
    1950Effie
    from no where
    Relic's right on! Poor attempt at traction control. Caused alot of chattering in the rearend when engaged.
  7. Shifty Shifterton
    Shifty Shifterton
    The jackpot? I've heard the center section called a lot of things, pig, pumpkin, etc. But jackpot's a new one. You learn something every day.
    PS be sure that's a 9", some of those cars used a similar diff that's not interchangeable and not aftermarket supported.
    Good luck with the project
  8. skip86
    skip86
    from Florida
    Speed sensor,feeds info to the Electronic Control Module(cars computer),;)Gerry
  9. 1950Effie
    1950Effie
    from no where
    No ECM in the any of the '70's Lincs. Just the first and second generation Dura-Spark ignition. The old gray box on the fender well with the pigtails coming out of it.
    Speed sensor would have been related to Anti-Locks brakes. Still a few years off in the F-L-M lines. But your close. The speed sensor in the later ones for Rear ABS looked the same. This ones for the the Sure Trac system.
  10. Relic Stew
    Relic Stew
    from Wisconsin
    The Sure-Track controller is up in the dash, near the glovebox. About the size of an 8-track tape c***ette. I wouldn't call it a computer.
  11. 41hemi
    41hemi
    Thanks guys for all the responses. The rear is actually a 9 3/8" rear. What does the Sure Trac actually do? Does it actually lock the rear? Hey Shifty, we been callin' the center sections- jackpots, pumpkins since I was a teenager. Must be a Baltimore thing:rolleyes:
  12. hotroddon
    hotroddon
    from a Ford brochure;
    This new feature allowed all four wheels to be controlled through a hydraulically actuated "Sure Track" system, which prevented wheel lock.
    Man, first I learn on the HAMB that some of you southern boys called what we in So Cal call a Pumpkin or Third member, a "Chunk", and now a "Jackpot". Any other off the wall names?
  13. flamedabone
    flamedabone
    Down here we call it a chunk or RGNP. (ring gear and pinion)
    Have also heard hogshead or just plain guts.
    -Abone.
  14. hotroddon
    hotroddon
    Hogshead? :eek: Where do you guys come up with this stuff :D
  15. FANTASY FACTORY
    FANTASY FACTORY
    On Long Island it would be a HAM.
    And there is plenty of support for ford 8" rears.
  16. bulletproof1
    bulletproof1
    from tulsa okla
    ive heard the hogs head one also...have no idea where it came from
  17. FoMoCoPower
    FoMoCoPower
    Sounds like it may be a 9 3/8" rear end,not a 9" and the gears are extremely limited for them.
  18. hotroddon
    hotroddon
    A 9" complete Pumpkin will drop right into a 9 3/8 rear end
  19. BigChief
    BigChief
    Alot of the 9-3/8" rears in the big Lincolns have tapered roller bearings at the axle ends and the ends (housing and axles) are different than the 9"rs....especially if the rearend has disc brakes (don't get this rearend confused with the once highly sought after disc brake equipped 9" rear from the Granada/Monarch/Versailles).
    The 9-3/8" rears are an orphan, they're usually too wide for the stuff we work on and parts aren't too easy to get. Add that in with limited gear selection and your better off leaving them where they lay or cashing them in with the next load of s****.
    -Bigchief.
  20. Paulie9fingers
    Paulie9fingers
    ... I've heard, and used, third member, pumpkin, center section and jackpot. I've given away quite a few of those Lincoln rears because of them bein' oddballs.
