History Photo repair?......Deuce Coupe
Discussion in 'The Hokey Ass Message Board' started by Royalshifter, Aug 28, 2009.
  1. Royalshifter
    Royalshifter
    Moderator
    This photo should have a full blue car but part has turned white and some writing on the rear quarter it should say Service Body Works and then under that Broadway which was a street in Fresno......above the rear wheel it also has writing but you only see faint areas of letters......also on the door I cannot completely make it out either. Can one of you photo restorers help.
  2. Hubbcat
    Hubbcat
    from Sweden
    so cool pic.
    god luck
  3. Royalshifter
    Royalshifter
    Moderator
    Same car if it helps.
  4. Hubbcat
    Hubbcat
    from Sweden
    is it a hemi in there?
  5. BoulevardBomber
    BoulevardBomber
    Are you sure that wasn't an intentional fade in the paint, because the rear wheel is undamaged, the 2 boys in front are way too washed out
  6. flatheadhero
    flatheadhero
    Joe or Jim Walker and Jack Fowler?
  7. if you lok it almost looks like it was printed off a printer as it was running out of ink...feed in first from the left side and you can see streaks of blue towards the rear....
  8. Royalshifter
    Royalshifter
    Moderator
    It is an Ardun.
  9. 7&7
    7&7
    from Colorado
    Bad *** car! I wish I could help Royal but I'm Ducking Fumb when it comes to this stuff. But I'll give you a bump.
  10. cuznbrucie
    cuznbrucie
    Looks like *Joe Walker* on the door......
    CB
  11. Royalshifter
    Royalshifter
    Moderator
  12. gericurl
    gericurl
    New here, but one thing I know is photo restoration (graphic designer)
    I will do my best with it. My only disclaimer is that it is difficult to create pixel data from nothing. There may be really light image traces I can use and I might be able to use the other photo to generate something similar.
    I'm happy to work on people's in exchange for the answers to all my forth-coming questions.
    Give me a couple of days to work on it between trying to get my new (old) truck to start.
  13. gericurl
    gericurl
    The word on the door closest to the guy's head is Jack and surname looks like Fowler? but I won't bet anything on it, but the first letter (partially covered by his head) looks to be an F and comparing the pixels of the last three letters "ler" look to be the same repeated letter forms from "Walker" above.
    There is also text in the middle that I can't make out. It is most likely not a name because it is written in a different text from the other 2 names.
  14. cheezwiz
    cheezwiz
    Here's a bit of a hack until a pro can do it...
  15. 49ratfink
    49ratfink
    here's mine. I couldn't bring the 2 guys up front out... unlike on TV you can't make things appear that are to small to be seen in the actual picture.
  16. stude_trucks
    stude_trucks
    If this is scanned from an actual photo that you have possession of, would help to have a higher res. scans with a couple at different contrast/color adjust settings to help recover some extra data. I am no photoshop expert myself, but more pixels/in and different settings = more info to work with.
  17. X426X
    X426X
    from OhiO
    Here is my amateur attempt, doubleclick on the attached thumbnail to enlarge.
    :cool:
  18. Royalshifter
    Royalshifter
    Moderator
    This photo all I have to work with and thank you guys very much.
  19. Royalshifter
    Royalshifter
    Moderator
    I finally received the good photo...isn't that car ****ing bad*** or what?
  20. Limey Steve
    Limey Steve
    Alliance Vendor
    from Whittier
    Jeez Skip that's Mental , look at the drilled frame or wheel well area ffs
    BAD****IN*** as they say :)
  21. Royalshifter
    Royalshifter
    Moderator
    Funny thing nobody knows where it is....the closest I got is the guy in the top left corner was the welding teacher at Clovis High School and built a Studebaker car for bonneville that had an Ardun engine....he still has it.
  22. vintagehotrods
    vintagehotrods
    Check out the sign too, "Live It Up With The Lively Ones From Ford'. I wonder what ever happened to the car. Maybe the HAMB Detectives can give us the rest of the story on it.
  23. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Love me some engine setback!!!!
  24. Royalshifter
    Royalshifter
    Moderator
    LA Roadster Show is where the picture was taken.....not sure the year.
  25. Hey, I've got a pair of those rear wheels in the garage right now!
    Steve
