water distribution tube dodge 230
Discussion in 'The Hokey Ass Message Board' started by harry37, Jul 29, 2009.
  1. harry37
    harry37
    I bought a basket case '49 Dodge 230 a couple of months ago, And its all stripped down except the water distribution tube. Its all mashed together and stuck in there and I need to figure out a way to yank it out of there. All suggestions are welcome.
  2. rodknocker
    rodknocker
    do you have a picture of the problem?
  3. Paul
    Paul
    Editor
    hook on a slide hammer?
  4. Not sure what a "water distribution tube" is, but if its a tube press fitted into the block or head, you should be able to grind it flush and cut down one side of what is left with a chisel. Maybe cut in two or 3 places and pick out the pieces.
  5. JohnEvans
    JohnEvans
    from Phoenix AZ
    +1 for slide hammer with a hook. Them things are just a hand push fit to start. now ya got some rust holding it in.
  6. sliderule67
    sliderule67
    from Houston
    What Paul said. Find the meatiest place you can to attach the hook. If you can get thru both sides of the tube, all the better. Some penetrating oil would probably help, and have some patience so you don't just tear the metal. More lighter taps is good. Bumping it loose by driving it in a little might also be helpful. Scribe a line on it so you can see what's happening.
  7. oldspert
    oldspert
    from Texas
    Leave it in and have your block hot tanked. It should come out easily after the rust is desolved.
  8. greaseguns
    greaseguns
    Make sure to put a new one in,I think it helps cool the valve seats.
  9. squirrel
    it looks like this from the front
    it's a sheet metal tube, kind of flat, with holes in it, goes back the full length of the engine behind the water pump, sends cool water to the valve area. If it's missing or rotted out or plugged, the engine will overheat.
  10. Thanks Squirrel..
    I was thinking he had a new name for heater hose ****** or similar.
    So chiseling won't work on that..
  11. The only way I could get mine out was by using a pair of the largest screw drivers you can find, 12" or bigger, jam each one into the tube at the front of the block and lever the blades into each side the tube as you push the screwdriver handles back toward the rear of the engine........its a real ******* trying to get it out, but essential to replace if you want the engine to run cool.....good luck.......for what its worth I tried various slide hammers, hooks, oil, etc over a period of about 3mths before the screwdrivers worked.......andyd
  12. The slide hammer and hook will really only work if it's not too badly rusted. The long screwdrivers is a good idea. I got 3' of 5/16" steel rod and ground a flat on the end like a screwdriver. Worked it down one side then the other. Also sprayed WD40 through the water holes in the deck. The ******* took two days to come out!
    Dont be tempted to leave it in there, you'll regret it.
  13. Do as the guy above said and hot tank it, if it is rusted bad that is the only thing that will free it up. if you booger the end up and can't get anything on it you are screwed. it needs the tube and they are still avalible new from a few sources.
  14. harry37
    harry37
    Thanks for all the advice guys, its soaking down right now. Sorry I didn't reply sooner I had some stuff going on. I don't know what a guy like me did for advice before this forum.
  15. squirrel
    I know what we did....we learned the hard way
  16. plym_46
    plym_46
    from central NY
    go over to p15 d25 forum there is a discussion on removal with a couple pictures of diferent tools folks have made. It is esential that you replace it as it does have a critical job of cooling the valve seats as well as regulating speed of flow.
    As a last resort, if the engine is out, one person threw caution to the wind and drilled a hole in the rear of the block and kocked it out with a log drift. The he taped the hole ad put in a pipe plug. But the home meade tool hooked to a slide hammer usually works.
    http://www430.pair.com/p15d24/mopar_forum/showthread.php?t=695
  17. hkestes
    hkestes
  18. AllSteel36
    AllSteel36
    I pulled mine from a 218 by clamping on vise-grips and twisting into a spiral, then tugging back and forth to loosen it up enough, then twisted somemore/etc,etc.
  19. C-1-PW
    C-1-PW
    You can sometimes find replacement distribution tubes made of br***. Something to think about as you hammer and chisel and slide hammer that ****er out of there.
  20. hemimerc
    hemimerc
    Got mine out with a 20lb slide and round rod with a hook and plenty of wd 40
  21. hemimerc
    hemimerc
  22. redramv10
    redramv10
    Distribution tube rusted solid to the block.
    I bent the sides in and latched visegrips. Got nothing.
    I used the slide hammer method, it tore the top of the tube.
    I then took a piece of flat steel about 1/16 thick, 3/4 tall, 12" long. Hammered it in along one side about an inch at a time, then slide hammered it out. add grease, hammer in again a little further. Did that until I had to use a longer piece of flat stock. Got to the point where I was tapping it the entire length of the head.
    Same procedure on the other side of the tube.
    After doing this to both sides of the tube, I was able to pull the tube out by hand.
