turbo 400 63 impala
Discussion in 'The Hokey Ass Message Board' started by chongo, Aug 29, 2009.
  1. chongo
    chongo
    from or
    hey guys i need help i put a t400 in my 63 wagon and i am stumped on shifting linkage, can anybody post a pic or give me pointers on how to change over and what to use. thanx in advance
  2. squirrel
    column shift or floor shift?
  3. chongo
    chongo
    from or
    column shift with powerglide, thanx
  4. squirrel
    Might be able to run a single rod from the column to the arm on the trans. You'd need an arm that has the right length and a hole on the end. Kinda like this
    http://www.cl***icchevy.com/product.asp?pf_id=19-19&dept_id=1849
    I think someone makes a similar kit for the TH350/400/700 for the 58-64 cars.
    Otherwise you could try to swap in the whole linkage from a mid 60s-70s car that has a TH400 or 350, with the cross shaft.
  5. chongo
    chongo
    from or
    thanx for the info, i like that single rod but 45 bucks wow the older i get the cheaper i get, i'm going to try and make one
  6. squirrel
    I just wanted to show you a pic, making your own is the way to go
