Smoker slicks...
Discussion in 'The Hokey Ass Message Board' started by Conder, Jun 21, 2009.
  1. Conder
    Conder
    One more thing to add....Y'know, for inspiration....with mucho respect and gra***ude!!!
  2. Cabbage
    Cabbage
    Great thread! I wish they would bring back the SMOKERS! Its much more exciting to watch, like back in the day when drag racing was super popular! Smoking the tires definately had something to do with the appeal. Seems to me the modern slicks grap and then "wad up" causing the tire shake
  3. sodbuster
    sodbuster
    from Kansas
    Zorba's Ghost @ the HAMB DRAG Nationals.
    Chris Nelson
    Kansas
  4. 64 DODGE 440
    64 DODGE 440
    from so cal
    Those pictures show what it's all about.......and how it should be.:D
  5. Toymaker
    Toymaker
    from Fresno,CA
    Bring it to Eagle Field Tim!
  6. firingorder1
    firingorder1
    Great thread! A fueler lighting them all the way and running a 7.80 at 210 is way more exciting than todays 3.90 at 310.
    Fontana 1964
    [​IMG][/IMG]
  7. KING CHASSIS
    KING CHASSIS
  8. adamabomb76
    adamabomb76
    from York, Pa
    I have to say that this was a nice read through. I think the theatrics of the cars of old where lost also, but that was a safty issue. They did have the exhibition cl*** back in the day though. What ever happened to that?
  9. KING CHASSIS
    KING CHASSIS
    People say it is hard to find a ghost. they should just follow its tracks. ha,ha. GEE, Wonder why I started peddeling it? A day in the life of a tire smoker. I love these damn things. [​IMG]
    On modern day prepared strips,,,, you need to stay in the groove. My car has a spool in the rear. Spinnin hard, and hittin different track surfaces only on one tire. Makes for one spectacural donut. And I dont want that to happen that far out.
    Come on everyone, climb aboard. Lets see this dream come true.
  10. KING CHASSIS
    KING CHASSIS
  11. landseaandair
    landseaandair
    from phoenix
    If I ever get to see two hard core historically accurate FEDs like ZG blazing their outdated hides full track, side by side, It would be nearly impossible to top. Keep up the good work.[​IMG]
  12. Conder
    Conder
    Hey Brian, maybe you've just invented something entirely new...!? Tiresmoking circle track!!!!
    How was it anyway, trying to steer the thing with the front wheels bobbing all over the place? How's the ****y bar sponsorship comin'? I can't believe you get to do this right now and I don't.....you mother!@#$%^&*(*&^%#@!.....I didn't mean that! Sorry.......!@#$%^&*((*&^%$#@^&*(*&^%$##$%^&*!!!!
  13. yoyodyne
    yoyodyne
    Which brings to mind a question - Why did the fuelers with open differentials never spin only one tire, always spinning both at the same speed?
  14. landseaandair
    landseaandair
    from phoenix
    I think between the the amount of horse power and the shock to the gears they basically locked themselves. Also, the lack of suspension and axle movement let both tires load more evenly. At least that's my theory.
  15. Kerry
    Kerry
    Brian, after watching you at the HAMB drags I'm having some serious thoughts about pitching my automatic setup and looking for a clutch, bell setup. $$$ would be the main reason I'd stick with the trans I have.
    I'd probably go with something like the Lump so I'd have a reverser. Are you out there Bob? Post some pics of the driveline in the Lump.
    And no Mark, I'm not taking the second hoop off of the top. ;-)
  16. smarg
    smarg
    Very interesting.
  17. OL 55
    OL 55
    Some inspiration..............:)
  18. adamabomb76
    adamabomb76
    from York, Pa
    Here is my unsolicited idea. They threw a little weld in the spider gears. It works wonders (I hear). Their are other ways of binding the axels, but I think that was the most popular.
  19. KING CHASSIS
    KING CHASSIS
    Most wernt welded. They were open. And I think is a better idea on a tire smoker dragster. So that when track surface changes per tire. Say left tire goes out of prepared surface and wants to spin harder it wont turn the car. Like a spool will. I want to try a open rear, but the only thing that scares me is spider gears. I have seen those stuck thru rear covers before. And we all what is there in a f.e.d. King
  20. KING CHASSIS
    KING CHASSIS
    Do it Kerry. You can add a reverser to the mix. I dont think the trans in the Lump would live behind your blown , injected Hemi. There is always Hemi clutch cans on ebay. Just try to hold out for one with a candlestick and fork. The fork isnt that important, because alot of those were just early ford forks. But the stick is important. Unless you have a gear makin shop you can work with to make you one.
  21. KING CHASSIS
    KING CHASSIS
    Conder , you nuts. In a good way.
  22. coupemerc
    coupemerc
    Guys, regardless of whether you're running an open differential, welded spiders (not recommended) or a spool, you should have about 2 GALLONS of fluid in the housing to help prevent rear end failure. Run the fluid level at least half way up the ring gear. If you don't do this, the pinion does not get oiled properly especially on the launch and it will eventually fail. Don't just run a couple of quarts like a street car does. Hope this saves some carnage... and someones balls.
  23. Conder
    Conder
    I'm takin' this pearl of advise to the bank...
  24. Kerry...my dad doesnt deal much in the computer world....ill find some pics of the driveline set up...but like brian said that greasy truck ****** probably wouldnt hold up behind a big HP chrysler....pm sent....
    T. Hilton
  25. yoyodyne
    yoyodyne
    You could fasten a cover over the openings in the posi case. I'm thinking 16ga steel and a few machine screws.
  26. yoyodyne
    yoyodyne
    But what prevents the tire with better traction from hooking up and spinning the other tire at 2X speed? When you say open rear, do you mean completely open or a posi with clutches?
    I ran a posi in my comp cl*** FED back when. We felt a posi could potentially go faster than a spool because of more forgiveness in it if one tire grew more - less drag. But I was only going 8's, nothing like fuel.
  27. rdefabri
    rdefabri
    from NJ
    They most certainly did spin one tire - I've got a great pic of a launch where one tire is tall and out of shape, the other has a normal profile and the rail is almost completely sideways. I don't have a scanner, but it's a pic out a '68 "Drag Racing Greats" mag I still own. There's also a pic of eastcoast's grandparents (Alison Lee working on the car with Ed Pink looking over her shoulder).
    Conder - I posted on another thread about your street / stock car idea - sounds like I have similar twisted thoughts in my brain. Don't have the $$ or the nuts that you and Brian do, but E'Town was my second home when I was a kid, and I caught the tail end of the smokin' FEDs. I also agree the Cackle cars are "whetting the appe***e" - I want to see these cars run in anger!!
    Don't know about the tires, but with respect to the modern tracks / surface - what about outlaw strips? Prolly don't have the width to do the push start from track end, but perhaps from staging? Could be a stupid idea, but what the hell...just a thought.
  28. yoyodyne
    yoyodyne
    I know that photo, I would have posted it if I could have found it. That could also have been caused by a broken axle. Why didn't it happen more often, and downtrack?
  29. rdefabri
    rdefabri
    from NJ
    Possibly, but can't tell enough from the photo.
    Not sure why I didn't happen more often - I am definitely not smart enough to know, but it's a valid question!
  30. coupemerc
    coupemerc
    Was talking to one of the east coast top fuel legends about these smokers this morning. He mentioned a few things...
    Last year at Oxford, Maine they push started their T/F car and did not let the driver use the reverser to get the car lined up. The crew had to push. He said the crowd went nuts.
    Their car did use a differential early on (pre 1970) but they used spider gears that they got from Donovan. A posi was not used in the car until around 1970 and the spools came later. All were used with no problems. He said "you could'nt tell the difference".
    The early smoker tire compound was definitely different than the newer compound that was formulated to hook up. If/when you did smoke the newer tire, you stopped moving forward. The old tire, smoking, with the correct wheel speed did not do that. It's too bad that we've recently lost Marv Rifchin. He'd remember the compound difference.
