318 wideblock problems
Discussion in 'The Hokey Ass Message Board' started by furyous, Aug 30, 2009.
  1. furyous
    furyous
    from tennessee
    hello i was looking for some advice and appreciate any help i get i have a 66 plymouth fury with a 318 wideblock that i just recently rebuilt it was bored 30 over, cam was reground by isky, has a weiand aluminum 4 barrel intake, new edelbrock carb,new electronic distributor and timed around 5 degrees btc it runs great as long as you stay in the throttle but when you take off from a dead stop it hesitates and backfires until you tap the pedal a little and stay in it this is first motor i have built solo any help would be great thanks
  2. 59ratgasser
    59ratgasser
    from BFE,kansas
    have you rebuilt the carb? Sounds like a lean condition
  3. squirrel
    says "new edelbrock carb" might need to set the float levels, might want to look at the ignition advance curve using a timing light. Sometimes aftermarket distributors don't have as much advance built in and need to start out with more initial advance. The only way to really know is to check the "total" advance, with a dial or readout type timing light or a timing tape on the damper. you want somewhere in the mid 30s total advance when you rev it up (vacuum hose disconnected if it has one).
  4. The Excellerator pump is putting out too much fuel when you step on it. Reajust it to do less fuel.
  5. squirrel
    sounds to me like the opposite...the accelerator pump is not doing enough. But retarded ignition timing will give the same symptoms.
  6. moparforlife
    moparforlife
    from Rolla, MO
    Try the idle mixture screws. Had the same problem with my 440. Messed with the idle mixture screws until I got it right. Start out at 1 1/2 turns out then 1 3/4. And some lighter springs for the distributor from Mr. Gasket also helped. Put a vacuum gauge on it too and tune until you get max vacuum.
  7. R Pope
    R Pope
    Gotta agree with 440, never seen a Carter or Eddie that squirted too much. They do have a problem with not enough sometimes. That sounds like your problem.
    BTW, they aren't "wide blocks." All 318's and 313's and 303's etc. are the same block sizes, the newer style heads are just narrower. Even 340 and 360 use the same size blocks.
  8. squirrel
    you mean it's really a poly? :)
  9. hotroddon
    hotroddon
    But some timing in that thing. At least 10 degrees, no wonder it's lazy, it wants some spark!
  10. 29nash
    29nash
    from colorado
    Yep, since 'getting on it seems to help the situation, sounds like it needs to be advanced a little.............
  11. garyf
    garyf
    Also look at distributor cap ign. wire towers for corrosion and ignition wires.One of these can be breaking down under engine load(or take off)and act fine at cruise speed and will cause your listed problem. .
  12. furyous
    furyous
    from tennessee
    hey guys thanks for all the advice it gives me some things to start eliminating i will keep you guys updated in case i need some more help and yes squirrel its a poly
