Paint Question
Discussion in 'The Hokey Ass Message Board' started by W Vaughan, Oct 19, 2004.
  1. W Vaughan
    W Vaughan
    from Benton Ms.
    I've got the 58 chev. ,I posted pics of a while back, ready to paint. I'm using PPG DBC 2000 B/C and 2002 clear on the main part of the body. I'm also painting the dash, jams, firewall, and all the interior trim. I don't know wheter to use the DBC and PPG speed clear or the PPG DBI interior color on the firewall jams and trim. The 2002 clear is just too damn expensive to use on the firewall and jams and I think it would be very wastefull on the trim pieces. My mentor at the local body shop suggested th DBI the paint store says use the base and a speed clear. Any ideas?
    Thanks
    Will Vaughan
  2. buffaloracer
    buffaloracer
    from kansas
    The paint that you are using is way too new and over my head. That being said, I've had a lot better luck following the advice of someone who regularly uses a product over that of someone in the store.
  3. born2late
    born2late
    Use the DBC base and clear it with PPG's Omni clear. Chemical and impact resistant as the 2002. Lots cheaper.
  4. TheGoose
    TheGoose
    from So, Cal
    Its called dupli-color....out of the can is the way to go... [​IMG]
  5. fishtank
    fishtank
    I would use the quick clear on everything other than the outer body. Not only is it cheaper, but it saves time.
  6. W Vaughan
    W Vaughan
    from Benton Ms.
    Thanks for the input.
    W Vaughan
