Blocks on the front? I didn't see any in the pics...now I gotta go back and look at the pics again...
Yep, I got it now, I just ***umed that was just built into the axle from the factory until I looked closer...I thought the dude was referring to drop blocks up front...
that is one cool *** truck. I would have left it alone, but lowering is cool too. I'd give it the killer "big and little" rake with cool dog dish hubcaps. when people ask how it rides tell them it rides as good as I want it to look.
what you said!! dog dish is the plan n i dont mind bump steer, its better than my jacked up 67 bronco!
I'm no suspension guru but I think you need to modify the steering arm on the back of the spindles rather than the drag link. someone who knows something about this should be along shortly to correct me or agree. hey... what's that in your avatar? you ought to be working on that.
Really like the stance before and after. You said you used a Mor-Drop axle?? Didn't know they made any for those year trucks. Unless you adapted it from something else. I have 2, 61 Uni's and a 57 F100. I want to do this to the 57 and also drop the rear as well but with out bags. Michael
i used the stock axle just put it ontop of the spring, i didnt want to go to low, n i hate clipped trucks
this is the truck i modeled it after, i liked the stance grill moon tank just wanted a little less drop
If you'd cut those rear bump stops down a lot shorter or replace them with some of those little urethane shorty ones you'd gain an inch of rear suspension travel. http://www.summitracing.com/parts/ENS-9-9121G/
Careful of using those "big truck" exhaust manifolds you speak of,they did not have the same bolt pattern as the y-blocks used in cars and light trucks.
the ford yblock ones of the ford motors do. the lincoln truck motors have off set bolt holes thanks for the tip though!!
Did you drill a locating hole in your front axle for the leaf spring pack locating bolt? I'm just trying to walk through the front axle drop in my mind in case I'm lucky enough to find one of these trucks...did you remove any leafs on the front or back?
yeah drilled a hole n when i get back from madison, ill some cash then. i want the center of the hood striped and the tail gate, so rock on!
hey there nice truck......i just picked one guy lost interest in. i really like it so far. mine is a 61,with a 351 in it. nice truck.............
