65 f-100, 352ci, won't start.
Discussion in 'The Hokey Ass Message Board' started by cruizinflames, Sep 7, 2009.
  1. cruizinflames
    cruizinflames
    from denver
    hey guys just bought a 65 ford, been sitting a few years. changed cap n rotor, plug wires. plugs. cleaned out carb. fuel filter, new gas. won't start. need points gap, dwell, and any other ideas. got spark from coil, fuel pump is fine. please help! i'm stumped!
  2. is it actually getting gas? look down the throat of the carb . pump the throttle and see if the accelerator pump squirts any gas. no smoking while doing that
  3. cruizinflames
    cruizinflames
    from denver
    yep, replaced acc. pump, gaskets, floats ok, cleaned out the carb totally.
  4. Kustom Komet
    Kustom Komet
    Point gap on about anything with points and no high power ignition is .035, check for spark at the plugs by holding a plug wire 1/2" from a ground source like the block (move the metal slightly out of the boot) while cranking with a remote starter and the ignition on. You should have a strong white spark jump from the wire to the ground. If not, no power from the coil to the distributer.
  5. cruizinflames
    cruizinflames
    from denver
    tried that too. maybe too much fuel?
  6. cruizinflames
    cruizinflames
    from denver
    thanks guys! Joe
  7. The Brudwich
    The Brudwich
    Did you try advancing the timing?
  8. BoulevardBomber
    BoulevardBomber
    sounds like timming, does it sound like it wants to start, spin fast, any more tips?
  9. cruizinflames
    cruizinflames
    from denver
    not yet, but will, thanks
  10. cruizinflames
    cruizinflames
    from denver
    yes it does. turns over fine, new battery, tries to fire, but won't
  11. your timing is off , maybe by a lot.. did you pull the distributor?
  12. odins701
    odins701
    Timing is out i bet. Go back to TDC on #1 and pull the cap and check the rotor for lining up with #1 and then check the firing order. You probably know this but just in case don't forget to recheck the idle evry time you adjust the timing (once it si running). :)
  13. VNTGE41
    VNTGE41
    from l.a.
    i second that . the timing and firing order is where i would start
  14. cruizinflames
    cruizinflames
    from denver
    no, didn't pull it yet.
  15. cruizinflames
    cruizinflames
    from denver
    well will start there, with timing ect. you guys are great! i just joined this site.
  16. odins701
    odins701
    If you didn't pull it you may have the firing order out. but definately check TDC just in case it was out before you got it.
  17. gaspumpchas
    gaspumpchas
    IF ITS been sittin a while, pull the plugs, clean if flooded, and squirt some oil in the cyls....flooding might have washed down the cyl walls,> poor compression.....good luck!!
    gaspumpchas:D
  18. cruizinflames
    cruizinflames
    from denver
  19. X426X
    X426X
    from OhiO
    Been setting a few years, eh? Might check for stuck rings, do a compression test.
    :cool:
  20. cruizinflames
    cruizinflames
    from denver
    never thought of the oil, will do
  21. retromotors
    retromotors
    I'll admit to bein' kind of a car dummy, (most of my experience is with motorcycles), but 35 thou sounds more like a plug gap to me. I'm more used to seeing about 16 thou on points.
  22. Side
    Side
    I always gaped my points with a match book. I highly recommend replacing your condenser.
  23. Special Ed
    Special Ed
    I think a matchbook is .018, if I'm not mistaken.
  24. The Brudwich
    The Brudwich
    .035 definitely is the plug gap, everything I've worked on had a points gap of .017 -.018
  25. retromotors
    retromotors
    Your post made me remember .... way back in the days when beer and soda cans had removable pull tabs (remember those!), one of the motorcycle magazines posted a list of all the popular beers with the thicknesses in thousandths of an inch. And yes, at that time there was a pretty fair spread of dimensions.
    Great info for roadside repairs ... particularly if you were riding a Britbike or anything else that depended on the Prince of Darkness for spark.
    I can picture the scene now:
    "Hey Norm, I found a Schlitz over here in the ditch."
    "Nah, keep lookin', I neeed a freakin' Falstaff!" :D
  26. cruizinflames
    cruizinflames
    from denver
    cool. thought that was more like a plug!
  27. flatheadpete
    flatheadpete
    from Burton, MI
    Won't start cuz it's too new for here. Look down;)
    ..............VVVV.................
  28. A Rodder
    A Rodder
    Have you confirmed if there is spark to the plugs yet?
