Projects my 54 ford
Discussion in 'The Hokey Ass Message Board' started by socalmisfit, Sep 7, 2009.
  1. socalmisfit
    socalmisfit
    here is my car i got a couple of years ago. the person that had it before wanted to repair the rust but didnt know what to do so they hacked it up a little. i have a little more to fix but its ok here is some pics
    here is some of the work that i have started last week i started the step notch and todat i stripped the rear axle so i can start mounting the four link tomorrow
    i tapered the frame rails back to the notch so it is square and not angled like it is stock. ill post more after the link is done.
  2. Looks like you're off to a good start on it. Ozelle the '55 Ford and Henrietta the '38 Ford pickup send friendly horn honks to your '54.
  3. scrap metal 48
    scrap metal 48
    Coupe body styles are really cool... Looks like yours is going to be really low........
  4. socalmisfit
    socalmisfit
    thanks man im going as low as i can i am even thinking about cutting the rockers down to about a inch and a half for a bodydrop. draggin is rad
  5. Ole don
    Ole don
    Outstanding work, gad I wish I were young and healthy enough to start one like that today.
  6. HOTRODPRIMER
    HOTRODPRIMER
    Are you keeping the ****er rear axle or opt for something a little stronger?
    BTW,,I thought you sold this car last week?HRP
  7. MUNCIE
    MUNCIE
    from Houston
    Very nice start what are your plans for the engine ****** combo?
  8. socalmisfit
    socalmisfit
    i did sell it but the guy gave it back to me after his wife chewed his *** and he said keep the money for the h***le lol. i guess the car wants to stay so i started to work on it. i think the axle will be cool it it just gonna be a cruiser
  9. socalmisfit
    socalmisfit
    i am getting a 302 and i dont know what trans i am gonna run yet
  10. MUNCIE
    MUNCIE
    from Houston
    :cool:
  11. Looking good man, nice strong welds and good planning. Any reason for the shape of the notch instead of just a flat top?
  12. Please keep the updates coming looks good so far.
  13. socalmisfit
    socalmisfit
    thanks man. i did the notch that way just to be alittle different and it makes it look a little smaller but still have the clearance. also im mounting the bags on the link so i dont have to worry about alot of stuff up high
  14. 1946chevytruck
    1946chevytruck
    from london ,ky
  15. -TKL-
    -TKL-
    looks good, like the notch like that
  16. Kustomline54
    Kustomline54
    Thats a great car your workin on. I got one myself thats "under construction". Those repairs on the body seem pretty straight 4ward. Good luck on the whole build, looking forward to seeing more pics. Itll make a cool lil cruiser. :cool:
  17. That notch is king,Keep us all posted on the progress.
    Keepin them low and drivem them slow....
  18. Bash'n'Weld
    Bash'n'Weld
    Can't wait until you tackle the sheetmetal repairs, luv watchin that stuff......subscribed!!
  19. socalmisfit
    socalmisfit
    thanks man
    thanks ill be posting more tonight hopefully
    as soon as i get the rear bags done im putting the body back on the frame and that is when ill start frankenstiening her back together lol
  20. lownslow
    lownslow
    looks good man . makes me really want to get back on my 54 . poor thing just sits there . too many other cars got done before it . kinda sad actually .
  21. socalmisfit
    socalmisfit
    built the 4 link bars today had alot of running around to do so thats all i got done today. its all hand made from tubing no kit stuff here. im gonna start making all the mounting tabs tomorrow night after work.
    before and after those r the best bolts to use
    all tig welded 1 1/2 tubing for the lower tubes and 1 1/4 for the top tubes
  22. Kustomline54
    Kustomline54
    Wow thats a killer looking frame and 4 link.Its getting done CLEAN. Hats off to ya Keep doing wat ur doing:)
  23. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    Socal
    I would not use that 54 rear as it is not real strong. Use a early mustang 8 in as they are just about the same width. Pull the backing plates off the 54 and put them on the mustang. That way you can keep the brakes the same as well as ease of hooking up the Emer brake cables.
    I have a 53 with a BBF and a C6. Broke the 53 rear 3 times then went to the mustang no more problems
  24. socalmisfit
    socalmisfit
    thanks
    thanks for the info but what was it that broke and what torque was you bbf puttin out im only planning on a small block and ive always seen shoeboxes run the stock rear and they work ok
  25. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    Socal
    I broke 2 Axles and one ring and pinion set. Its a stock 390 so I guess 370 ft pounds. I am not sure the power is what did it as I am running G78 Wide Whites on 6in Chrome rims.
  26. Kustom7777
    Kustom7777
    from Austin, TX
    i like those cars,,looks like you are off to a solid start...NICE welds, by the way....
  27. desertdroog
    desertdroog
    Neat post, I really like '54 Ford Coupes...don't see too many around.
  28. phqnflt
    phqnflt
    from NOR CAL
    The body on yours looks about the same condition as I got mine. What rear end are you using, and who's 4link are you using, or are you making your own?
  29. phqnflt
    phqnflt
    from NOR CAL
    I guess I should realy read the whole post before posting. still a nice set up.
