I've decided to run my radiator in the bed of my '28 PU and figured out the plumbing but I want to put my waterpump in line and mount it under the cab. Who makes an inline electric pump that is tough enough to be considered streetable? If I can find the right pump that would finish out the cooling system on my tweeked little hauler. Hint Hint...blown, tripower, 283, zoomies, spooled rearend and slicks and a sickness for altereds
Electric water pumps are pretty commom now. I'd try some of the big performance parts suppliers as a starter. Not sure if you have these in the states, but I'd go for a Davies Craig water pump (www.daviescraig.co.au) their cheap, small and can be mounted anywhere. If on the other hand you want a period electric water pump, I think you have a long search...
The stock pump will move alot of water a long way. otherwise id use marine mechanical pumps..check out the boat parts places online..lots o neat stuff
