model a coupe chop. help!
Discussion in 'The Hokey Ass Message Board' started by kieran, Sep 8, 2009.
  1. kieran
    kieran
    from San Diego
    so i chopped my coupe 5.5 inches and when i set the roof back on, the top
    "a" pillars are about 1/2 in too wide. any suggestions?thanks-kieran
  2. hvychvy
    hvychvy
    I used a ratchet strap,and pulled mine together,but I'm not shure mine was quite that far off.You might hafe to do some relief cuts,at top,and bottom of the a pillar,and meet in the middle.Just take your time,and it will turn out.
  3. Pinewood
    Pinewood
    Pie cuts are your friend.
  4. temper_mental
    temper_mental
    from Texas
  5. 19-c
    19-c
    they will be wide. You will have to make a couple small relief cuts to bring them in. also if you have not used a filler peice inside the pillar i would drill a couple holes in the pillar above and below your cut slip some metal stock inside the pillar and secure with some rossette welds this will add strength to your chopped pillar.
  6. Krash
    Krash
    from Cleveland
    I chopped my sedan 4 inches and had to make 3 pie cuts on the A pillars. Two on the bottom and one on the top. Then it lined up perfectly.
  7. kieran
    kieran
    from San Diego
    thanks for the input. im just worried about the windshield frame fitting back in. any pictures of the relief cuts you guys are talking about. i dont quite understand where i need to do them.
  8. Krash
    Krash
    from Cleveland
    Forgot.....Kieren my sedan is literally the same exact color with the same patina.....sort of a robins egg blue. Aso, I made 3 verticle relief cuts on the c pillars and it also lined up perfectly. I then made wedge cuts in all the window openings.
  9. kieran
    kieran
    from San Diego
    wedge cuts?
  10. Lazy White Boy
    Lazy White Boy
    I used a port-a-power on the bottom, pie cuts on the top. Be gentle with the port-a-power, I used it to get that last 1/8th inch or so. It all lined up great. My chop was 5".
  11. kieran
    kieran
    from San Diego
    anyone have pictures?
  12. HotRodBen1987
    HotRodBen1987
    yea pie cut it like everybody else said. looks good by the way
  13. scootermcrad
    scootermcrad
    Check out the Rolf coupe build in the Tech Index! That will answer a couple questions for you.
    Like everyone else said, you will have to make some pie cuts and you will have to refit the windshield frame with that chop. No big deal. If you can cut, weld, grind, and blend, you can do everything else you need to.
    Pie cuts are the way to go though. LOTS of pie cuts on my pillars man!
  14. kieran
    kieran
    from San Diego
    thanks
  15. Rodder29
    Rodder29
    Good point. But do this after the pie cuts.
  16. Just Gary
    Just Gary
  17. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Your pie cuts should be big enough to take out any "pre-load".
    Make pie cuts
    Pull posts together with ratchet/come along
    Take load off ratchet
    Weld
    Once you pull the posts in place, you should be able to take the load off the ratchet and have the posts stay in position without any 'help'. Holding the posts together with the ratchet while welding is going to place preload on the posts (they'll always want to pull apart and place stress on the joint).
    Chop looks great!
  18. Ian Berky
    Ian Berky
    Looks great Kieran!! Yep!! Pie cuts, started a 49 ford chop yesterday and pie cuts are your friend!!:):)
    Ian
  19. kieran
    kieran
    from San Diego
    man i bet your stoked
    thanks! those pictures helped me alot
  20. Since I was not running a stock dash, I cut the dash rail, cut the bottom out of the gas tank, spread the tank and welded it in. I cut down a 38 ford dash to fit and centered the window frame in the opening. Looks good. I cut my top 5"
