1932 Pickup Build
Discussion in 'The Hokey Ass Message Board' started by Salt Flats Speed Shop, Mar 27, 2008.
  1. send_it_all
    send_it_all
  2. 29 rattrap
    29 rattrap
    from New York
    Where did you get those tires on the front?
    what size are they?
  3. Salt Flats Speed Shop
    from Utah
    The rims and tires on the front are from coker tire. They are the firestone dirt track 15" fronts. Just make sure that you get the ones that don't have the "display only" on the tires. Ive heard horror stories about those being out of round.
    The rims are just chrome steelies.
  4. kisam
    kisam
    I'd say the chop looks perfect. Wish the one I am working on looked that good. Also I wished they had taken the chop out of the top of the windshield post instead on the middle (now the post will have to be pie cut to make it right). Anyway I am loving this build!
  5. SchlottyD
    SchlottyD
    Excellent craftsmanship going into this little hotrod, absolutely love the front crossmember and spring mount.
  6. landseaandair
    landseaandair
    from phoenix
    First off, that truck looks pretty sharp and you've definitely got some skills. If you're still open to suggestions as far as how to beef up the ch***is, I studied it and and drew up one option. The rear is simple enough, although you may see fit to adjust it some to suit your situation. The front along with the rear could be done with 1 5/8" ? tubing attached to the frame with large weld in clevises (basically rollcage swing out door bar ends) and tabs, allowing easy removal. The only difference being a shear panel between the frame and the dropped bar running across the door opening. It could be flanged on the bottom to bolt to the frame rail. It looks like your narrow seats and width of your rails would allow for it, but I could be wrong. If the tubing is heavy enough, you may be able to flare it slightly without weakening it too much. Done this way, it should be plenty strong, although a cowl and/or main hoop could be incorporated. Just an idea.
  7. landseaandair
    landseaandair
    from phoenix
    Yaay! my first picture. Much success.
  8. Salt Flats Speed Shop
    from Utah
    Thanks for the input! I think that would work perfectly.
    I made a drawing in illustrator that I think is the way I want to go. I want this to be removable for ease of painting. I should be able to have the front hoop, that my steering and brakes hang off of, welded on to it. Then the rear hoop, that my seat belts attach to can be bolted on top as well as to the rear posts of the cab.
    Ill be changing the way the rear part of the frame connects to the section under the cab. I just want to keep as much of the rear floor as possible. I also will still put a bolt in brace across the arc but to make it not stick below the bottom of the bed it will just go straight across.
    Thanks again for the great idea!
    <table style="border: medium none ; font-family: Myriad,Helvetica,Verdana,sans-serif;" width="768" border="0"><tbody><tr><td colspan="2" style="border: medium none ;"><embed type="application/x-shockwave-flash" wmode="transparent" allownetworking="all" src="http://w667.photobucket.com/flash/tagWidget.swf?mediaURL=aHR0cDovL2k2NjcucGhvdG9idWNrZXQuY29tL2FsYnVtcy92djM2L1NhbHRfRmxhdHNfU3BlZWRfU2hvcC8xOTMyJTIwU2hvcCUyMFRydWNrLzE0OS0xLmpwZw%3D%3D" width="768" height="576"></td></tr></tbody></table>
  9. Deu55
    Deu55
    That is one cool shop truck..Rod..
  10. landseaandair
    landseaandair
    from phoenix
    Well look at you and your fancy computer magic. Glad if I was any help at all. If anything it was a good reason for me to finally figure out how to post pictures. Now I just need to get a digital camera so everyone can see my piss poor excuse for a project.:)
  11. Flathead26T
    Flathead26T
    Awsome shop truck. Cant wait to see more updates!
  12. willysguy
    willysguy
    from Canada
    Now that made me chuckle! You da man Chris! Looks right on!;)
  13. Salt Flats Speed Shop
    from Utah
    I started on the chop the other day. With it all cut apart I will go over the separate panels and fix all the dents and rust issues. Then I will start putting the chop back together.
    <table border="0" width="1024" style="border: none; font-family: Myriad, Helvetica, Verdana, sans-serif;"><tr><td colspan="2" style="border: none;"><embed type="application/x-shockwave-flash" wmode="transparent" allowNetworking="all" src="http://w667.photobucket.com/flash/tagWidget.swf?mediaURL=aHR0cDovL2k2NjcucGhvdG9idWNrZXQuY29tL2FsYnVtcy92djM2L1NhbHRfRmxhdHNfU3BlZWRfU2hvcC8xOTMyJTIwU2hvcCUyMFRydWNrLzE2NC5qcGc%3D" width="1024" height="768"/></td></tr></table>
    <table border="0" width="1024" style="border: none; font-family: Myriad, Helvetica, Verdana, sans-serif;"><tr><td colspan="2" style="border: none;"><embed type="application/x-shockwave-flash" wmode="transparent" allowNetworking="all" src="http://w667.photobucket.com/flash/tagWidget.swf?mediaURL=aHR0cDovL2k2NjcucGhvdG9idWNrZXQuY29tL2FsYnVtcy92djM2L1NhbHRfRmxhdHNfU3BlZWRfU2hvcC8xOTMyJTIwU2hvcCUyMFRydWNrLzE2NS5qcGc%3D" width="1024" height="768"/></td></tr></table>
    <table border="0" width="1024" style="border: none; font-family: Myriad, Helvetica, Verdana, sans-serif;"><tr><td colspan="2" style="border: none;"><embed type="application/x-shockwave-flash" wmode="transparent" allowNetworking="all" src="http://w667.photobucket.com/flash/tagWidget.swf?mediaURL=aHR0cDovL2k2NjcucGhvdG9idWNrZXQuY29tL2FsYnVtcy92djM2L1NhbHRfRmxhdHNfU3BlZWRfU2hvcC8xOTMyJTIwU2hvcCUyMFRydWNrLzE3MC5qcGc%3D" width="1024" height="768"/></td></tr></table>
    <table border="0" width="1024" style="border: none; font-family: Myriad, Helvetica, Verdana, sans-serif;"><tr><td colspan="2" style="border: none;"><embed type="application/x-shockwave-flash" wmode="transparent" allowNetworking="all" src="http://w667.photobucket.com/flash/tagWidget.swf?mediaURL=aHR0cDovL2k2NjcucGhvdG9idWNrZXQuY29tL2FsYnVtcy92djM2L1NhbHRfRmxhdHNfU3BlZWRfU2hvcC8xOTMyJTIwU2hvcCUyMFRydWNrLzE3MS5qcGc%3D" width="1024" height="768"/></td></tr></table>
    <table border="0" width="1024" style="border: none; font-family: Myriad, Helvetica, Verdana, sans-serif;"><tr><td colspan="2" style="border: none;"><embed type="application/x-shockwave-flash" wmode="transparent" allowNetworking="all" src="http://w667.photobucket.com/flash/tagWidget.swf?mediaURL=aHR0cDovL2k2NjcucGhvdG9idWNrZXQuY29tL2FsYnVtcy92djM2L1NhbHRfRmxhdHNfU3BlZWRfU2hvcC8xOTMyJTIwU2hvcCUyMFRydWNrLzE3Mi5qcGc%3D" width="1024" height="768"/></td></tr></table>
  14. tboats52
    tboats52
    from SE WI
    Outstanding!!!!!!!!
  15. smith32
    smith32
    Wow, awesome work here....... i been following along on an A Coupe build you have been doing but dammm this one just blows my mind
  16. Rocky
    Rocky
    Classified Editor
    Go for a 6" chop, man.....I cut mine 5.5" and thought it was ***s until 2 days later I saw one cut 6 inches...that extra 1/2 inch looked great! Mine was channelled the width of the frame too and at 5'9" I still had an inch and a half head-clearance with the mini-van seat on the floor.....was easy to see out of in all directions because your face is always close to any window in the cab...
    BTW, taking a slice out of a 49-50 ford dash makes it fit a 32-34 ford pickup and the stock 49-50 gauges work great..
    Here's mine with a 26 T bed and 5.5" chop.
  17. PonchoJohn
    PonchoJohn
    from Fresno, Ca
    Any updates on this build?
  18. justnicholas
    justnicholas
    I just read this entire thread and was in awe. Hope theres some more posts.
  19. hemifarris
    hemifarris
    Nice build......great ch***is!
  20. Salt Flats Speed Shop
    from Utah
    Unfortunately I sold this pickup to my dad last year to help fund my 32' Tudor sedan. I was sad to sell it, but its nice to know its still in the family.
  21. 3wLarry
    3wLarry
    from Owasso, Ok
    aarrgh...was hoping to steal ideas...now what am I gonna do? :D
    kidcampbell71 likes this.
  22. blackmopar
    blackmopar
    from fallbrook
    thing looks great! im trying to fenagle one of these cabs from my neighbor - old man knows what he has though! aargh
  23. 10secondA
    10secondA
    that frame is amazing i like it
  24. krylon32
    krylon32
    from Nebraska
    Larry: You don't need no dam blueprints, just follow the picture you had in your original thread, it don't get no better than that.
  25. CWTC10
    CWTC10
    from Arab Al
    Any updates on this one?
  26. Salt Flats Speed Shop
    from Utah
    I sold the cab, bed, and some of the frame to my dad cause he really wanted a shop truck. That's when I bought my 32' sedan, and that's now my personal project.
  27. orangepeel
    orangepeel
    from arvada, co
    More amazing work Chris. Cant wait to comeback for your open house next year during speedweek. Did you ever get any shop logo decals done up????
