Projects OT - My Compressed Air Vehicle
Discussion in 'The Hokey Ass Message Board' started by A-Wall, Sep 17, 2009.
  1. A-Wall
    A-Wall
    Since i've had the Model A, i've become fascinated with everything old and mechanical. Why it works, how it works, how reliable it was.... and so on. Everything was easy to fix and well designed (for its time).
    Steam powered, oil engines, hit & miss, flame lickers i love em all!
    So I decided to build a useless vehicle last night at 7pm. No plans other then it was going to be 3 wheeled using my compressed air engine. Good thing i keep everything, i used up the rest of the bike parts in my s**** pile and a bunch of tubing under my bench. i didn't measure a thing, just cut and weld. I had the whole thing finished and rolling in 3 hours. No idea it would even work!
    This was just to experiment and learn. Maybe someday i will make it gas powered so i can actually drive it a distance.
    Pics from last night at 10-11pm
    [​IMG][​IMG][​IMG]
    Today my buddy came by and i decided to hook up some hoses and IT'S ALIVE!
    It feels like i've gone back to the late 1800's or something!
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/RcgtWjtk8Dc&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/RcgtWjtk8Dc&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/1JoPOnC5d-M&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/1JoPOnC5d-M&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/SKlzYojDB4Y&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/SKlzYojDB4Y&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
  2. Man, that is completely Steampunk! I love it! Maybe not the fastest in the world, but that's what hotrodding is all about. :)
  3. redlinetoys
    redlinetoys
    from Midwest
    COOL! You need a trailer with a BIG air tank!
  4. A-Wall
    A-Wall
    Ya it's definitely not fast but it's still amazingly fun to drive around.
    100% agree!
  5. LaidoutRivi63
    LaidoutRivi63
    what kinda little motor is that? what vintage?
  6. A-Wall
    A-Wall
    its a 90's te***seh engine that i added lobes to the cam shaft to make it run on compressed air.
  7. MarkzRodz
    MarkzRodz
    I'd like some skid pad numbers ,,the best part was the last vid where she was lope'n.
  8. Fordguy78
    Fordguy78
    That is awesome. Just think, somebody back in the 1800s built something similar to this and when it worked, they said to their buddies, "Hey guys, check this **** out!"
  9. RichG
    RichG
    That is so cool! Give a hot rodder some materials and time and he'll come up with just about anything!
  10. A couple of nitrogen tanks mounted on the *** of that thing, maybe a gear/pulley setup with chain or belt....woooo. That things cool man. Same kind of stuff my friend builds...just off the wall crazy ****. Everytime I go to his house he's got some new contraption and he says "wanna ride it?"
  11. MarkzRodz
    MarkzRodz
    Hey! thats a bong in the back ground !
  12. plym_46
    plym_46
    from central NY
    Can you say underslung nitrogen tank, or 2 ???? I can. need more speed open the regulator.
    Or at least on of those water ski tow rope risers so you don't need to aorry about fouling the supply hose.
  13. A-Wall
    A-Wall
    thanks guys!
    That would be cool. I make all kinds of stuff too. im usually too fussy tho to make something this quickly.
    Wat?
  14. A-Wall
    A-Wall
    ya right now running off my compressor i dont gain any speed with the regulator wide open, i dont have the volume needed with hose diameter and this regulator.
  15. Since it's all in fun, it might be worth experimenting with some type of bike derailleurs & gears to have a "transmission" of sorts....might be able to make it efficient enough to actually run for a bit off an air tank, though probably not more than a minute or so. Nevertheless, it would be neat to see what happens even with larger diameter air hose.
  16. Toast
    Toast
    from Jenks, OK
    Or a really long hose:D
  17. A-Wall
    A-Wall
    ive got 2 more in the shop i could connect! it would probly be enough to make some p***es on the road lol.
  18. Insane 1
    Insane 1
    from Ennis TX
    I like the way it sounds.
  19. budd
    budd
    air cars have been around a very long time.
  20. chaddilac
    chaddilac
    you should show this over at ratrodbikes.com!
  21. pasadenahotrod
    pasadenahotrod
    from Texas
  22. budd
    budd
    now go get yourself some old aluminum scuba tanks and a paintball compressor and you can drive it to the corner store.
  23. A-Wall
    A-Wall
    wow great article! thanks!
    what kind of pressure do they run and cubic feet air could you hold?
  24. gnichols
    gnichols
    from Tampa, FL
  25. zzford
    zzford
    What is the transmission from? Your creation needs to be flat black with red wheels.
  26. Tudor
    Tudor
    from GA
    Wow - Can you explain this? If I understand correctly it was a gas engine and you only modified the cam? What's the theory behind adding the lobes? sounds cool.
  27. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    26 replies, and I'm the only one who mentions fart-power? Geez........... ;)
  28. budd
    budd
    scuba tanks need to have a hydrostatic test done every so often, the test can have them up to 10,000 psi, but when in use there more like 3500 psi, a scuba/paintball pump is around 3500 psi, what that means in volume i don't know, scuba tanks that don't p*** hydro sell for s**** price, i was told i could buy lots of them for $25 each or less, have you seen the new french air car, the motor is more like a two stage compressor.
  29. JRODHOTROD
    JRODHOTROD
    from Manor, TX
    2 stroke vs 4 stroke. removes the compression stroke.
  30. Tudor
    Tudor
    from GA
    Oh that totaly explains it - thanks :D
