Flathead engine
Discussion in 'The Hokey Ass Message Board' started by sir.tooby, Sep 17, 2009.
  1. sir.tooby
    sir.tooby
    from Sweden
    Hi!
    I am trying to make a Flathead engine in 3D and need "some" help of you that have those engines....
    I am just trying to get the look right:rolleyes: so that I can use the engine for my 3D projects.
    If you have engine parts and measures that you would like to share I would be very happy:D (Best is if the pictures is left/right/top and side views)
    I attach a Edelbrock cylinder head (text missing): Is it good enuff?
    Best regards
    sir.tooby
  2. Vergil
    Vergil
    The head looks great sir.tooby
    Vergil
  3. Mr48chev
    Hey that would fit the flattie I have out in the garage. Looks pretty good from here. Lets see the next installment.
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
  4. sir.tooby
    sir.tooby
    from Sweden
    Thanx!
    @ Mr48chev: Could you give me length, width and heigth?
    Do you have some good pictures to share, the one i find on the net is often to small in from wrong angle. Would be super if you could help with pictures of different parts (to much to ask for perhaps). I have never seen a Flathead in real life but I really like the looks of it.
    To be able to do a 3D picture I need (at least) a side view and som measurements but best is side, front, back, top and bottom pictures + measure.:eek:
    Would be great with a engine block as next to do item:D
    Best regards
    tooby
  5. 31ACoupe
    31ACoupe
    not much help with the block but here is what I have, nice intake w/strombergs too.
  6. sir.tooby
    sir.tooby
    from Sweden
    Thanx!
    It will help me! Do you have som mor pictures of that nice intake and the carburators? I will try to start making the engine block...and hope for a good result.
    Is it possible for you to measure the width/length of the block?
    Best Regards
    tooby
  7. sir.tooby
    sir.tooby
    from Sweden
    Not done much...don't know where to start block or intake. I have found some pictures here at H.A.M.B so hopefully I will find a way to start modelling.
    Best Regards
    sir.tooby
    Added sparkplugs and test to cylinderhead.
