Customs What is "PROPER STANCE"????
Discussion in 'The Hokey Ass Message Board' started by COS, Sep 17, 2009.
  1. KIRK!
    KIRK!
    Also, a hot rod CAN BE TOO LOW!
    While we're at it, more chop DOES NOT EQUAL MORE COOL!
    The right amount of chop does however equal COOL!
  2. Frenchy32
    Frenchy32
    from arizona
    Here is the proper stance
    Frenchy
  3. joeycarpunk
    joeycarpunk
    from MN,USA
    I would agree, does the car (hotrod or custom) scream "CHOPPED" or do the lines look proportioned.
    Same is true for lowering, some cars just look broken.
    You'll get alot of opinions and it depends on the car. Like grandpa used to say, "If we all liked the same thing, we would all be sleeping with grandma."
  4. tommycarpunk
    tommycarpunk
    from Milaca, MN
    I just dropped my 63 1/2 Galaxie 3 inches in the rear with blocks. Had to cut out the drive shaft tunnel out under rear seat to stop it from rubbing form a new one and weld it back in... TOTALLY WORTH IT!!!! Pile up here I come "dragging tail" all the way!
  5. Pinstriper40
    Pinstriper40
    proper stance to me means ***-low for pre '53.
  6. hotrodladycrusr
    hotrodladycrusr
    2005, Big Olds with no interior, windows, top, etc. I knew the stance wasn't were I wanted it BUT I also knew I needed to wait till I had all the weight in the car to determine how much lower I wanted to go in the front.
    2009, after everything was completed including 2 inch drop spindles installed.
    Might not look like alot in the photos but really made a differance in person.
  7. xtralow
    xtralow
    This 55 sits good IMO
  8. nose down *** up thats the way i liked to.... oh wait we're talking about cars.
  9. Mark H
    Mark H
    from Scotland
    Stole these pics from the 'net;
  10. Mark H
    Mark H
    from Scotland
    This one's really draggin' it's ***!
  11. my47soto
    my47soto
    Thanx for the encouragement to ask questions that you should already know the answer too. Cause your opinion an someone elses can be totally different.:eek: In my opinion is low sleeek and ***y with the tail draggin like it's a beautiful fat ***.:cool:
  12. LOWBLAZERO1
    LOWBLAZERO1
    agreed, but a custom can not :D
  13. zman
    zman
    from Garner, NC
    I have to disagree, a custom can be to low as well. Sitting on the ground is not a stance.
  14. Detonator
    Detonator
    from santa cruz
    LOL, one of my favorite lines ever came from someone here on the HAMB: "If ya can't sleep under it, it ain't a highboy!"
  15. caddy man
    caddy man
    from usa
    Here's my two, both have bags, one's a custom and one's a streetrod.
  16. brownsmetal
    brownsmetal
    My opinion of proper custom stance.[​IMG]
  17. My 50 Buick, I like the stance. Rags
  18. Rasmus
    Rasmus
    from Las Vegas
    "Proper Stance" occurs when you set the space between your frame and the ground 1/2 inch less then the average speed-bump height in your town.
  19. oilslinger53
    oilslinger53
    from covina CA
    draw a line from the bottom of the front rim to the botton of the rear rim. The bottom for the car should be parallel to, and no lower than this line. Talkin rods here not customs. Thats a different story.
  20. xtralow
    xtralow
    Skullcrackers 55 has the proper stance
  21. I worked long and hard to get the stance right on my old truck. I think I nailed it. Is it too low? I don't think so. Scrub line ****s but I drive the snot out of it any way.
    Later,
  22. KIRK!
    KIRK!
    Just short of being too low.
  23. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I would consider that a near perfect (if not perfect) stance for a custom. I dig the way the Sam Barris Merc sits. It's not completely hammered but certainly has stance and style. Your car follows that same formula too I think.
  24. PeteFromTexas
    PeteFromTexas
    For customs just look at Larry Watson's "The G****vine" or Duane Steck's "Moonglow" or Lanny Ericson's "Violet Fantasy". Those are on the low side. On the high side look at Reverend Larry Ernst '51 Chevy. That car is perfect. Those are all somewhere around perfect in my book.
  25. dannyego
    dannyego
    that there is an Indiana race car:D at least thats what we called cars jacked up in the back in Chicago
  26. 61TBird
    61TBird
    That's Stock height in the rear.(I cut 1 1/4 coils off the front)
    Being out of work and having to pay for job training cuts into my car fund to lower the rear with 2" blocks.
  27. Shawn M
    Shawn M
    Is that possible on a Custom? Here are my two. Not low enough to suit me yet, but close.
  28. hot rust
    hot rust
    x2 maybe they just need to be told
  29. lockwoodkustoms
    lockwoodkustoms
    I consider mine a Hot Rod stance.........not sure if anyone else agrees
  30. captain scarlet
    captain scarlet
    from Detroit
    Works for me too. Great looking car:cool:
