stationary quarter windows
Discussion in 'The Hokey Ass Message Board' started by luxloco, Sep 22, 2009.
  1. luxloco
    luxloco
    i need some help on how to put in stationary quarter windows on a chop ie. how to mount,molding etc. thanks for any help
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    First...WHAT kind of car are you working on?
  3. luxloco
    luxloco
    sorry its a 52 ford two-door customline chop 4.5 in front 6.5 in rear
  4. luxloco
    luxloco
    any help please.
  5. CURIOUS RASH
    CURIOUS RASH
    Classified's Moderator
    Pictures would help...
  6. luxloco
    luxloco
  7. SHRUM
    SHRUM
    Picture didn't work, can you try it again?
  8. luxloco
    luxloco
    i only have the outside pic I'll try to get a inside pic later
  9. pasadenahotrod
    pasadenahotrod
    from Texas
    You can use u-channel rubber to seal against the outer body flange and make up a spacer frame or spacers around the window opening which would hold the gl*** in place using the original inside trim moulding.
  10. luxloco
    luxloco
    whats the best adhesive to use ?
  11. 32SEDAN
    32SEDAN
    I used round gl*** tape (black) for a similar application. Sticky stuff! Keep your hands wet when you apply it.
