What Wheelbase? Model A
Discussion in 'The Hokey Ass Message Board' started by tmacracin, Sep 25, 2009.
  1. tmacracin
    tmacracin
    Looking to get some ideas for my new chassis for my street/strip pickup. Here are the specs:
    -28 Ford closed cab,28/29 grill shell
    -2"x4" chassis,drag race ladder bar setup,4" drop axle,9"rear 4.11 gear
    Brookville front crossmember,
    -blown 355SBC(500hp),2" belt drive,powerglide/transbrake,3000 stall
    Its 8" to the outside of the blower belt from the four mounting holes on the front of the block. I'm thinking 108"-110" to make it fit with the stock firewall?
  2. fiftyv8
    fiftyv8
    from CO & WA
    103 15/32 inches center of front wheel to center of rear wheel.
    Good luck.
  3. tmacracin
    tmacracin
    Thats stock specs
  4. fiftyv8
    fiftyv8
    from CO & WA
    Yep, if you are running fenders that is what you should be aiming for.
  5. 31modelo
    31modelo
    Flip the firewall stuff the motor back and it'll fit stock wheel base (103 1/2). Better weight distribution and nothing looks better than a motor stuffed way back.
  6. You cant do that if you're taller than 4 foot, there's bugger all room in those things at the best of times.
  7. 31modelo
    31modelo
    Didn't look close enough it's a pickup. Yeah that would be tight but cool.
  8. striper
    striper
    Hard to flip the firewall on a 28 / 29 too.
    Mine's 109". Totally different deal but I don't think it looks too stretched.
  9. Cirelli
    Cirelli
    1. H.A.M.B. Chapel
    On my 29 Model A Sedan, I have a 132" wheelbase. I needed the foot room, so I moved the hemi engine forward 8" to get the bellhousing out of the passenger compartment. Then with the blower drive in the front & a laid back 32 grille shell, the front end got way out there. However, I just set my Ackerman angle for that length. I have a good turning radius & it handles just fine. Also helped smooth out the ride.
  10. Mat Thrasher
    Mat Thrasher
    On my 34 pick up with a blown bbc I'm at 113". I would think 110 would work for an A pick up with a sbc.
  11. 31modelo
    31modelo
    striper that nailhead helps you pull off that wheelbase thats a long motor. I'm a fan of proportion and those SBC's don't need alot of space that's one of the reasons they started gettin used so much.
  12. pompadour
    pompadour
    Keep it close to stock...I'm running 104.5 which gives me just a little more room for the engine...Don't go over 106 or it will look wierd...My 2 cents
  13. tmacracin
    tmacracin
    Yes its going to be fenderless.I don't have the room to recess the firewall.I will try to keep around 106-108"
  14. scrap metal 48
    scrap metal 48
    Can't flip firewall on 28-9............
  15. hotcargo
    hotcargo
    My '29 closed cab on '32 rails , is stock '32 wheelbase 106 1/2 ...with blown hemi .....proportions are right with my eye .....
    cheers Steve in Oz
  16. tmacracin
    tmacracin
    2" or 3" belt drive? What altenator and steering box are you running?
  17. 60'shotrod
    60'shotrod
    I've gone 106'' just enough room for my sbc, but I will have to add a notch/bulge in the firewall for the dizzy.I think 106'' looks just right and not too long.
    Nick.
  18. hotcargo
    hotcargo
    3" drive , Running a GM steering box , cross steer fashion ,
    671 blown 354 hemi
    running the water pump , alternator , distributer off a separate drive with toothed belt under the Vee of the engine .....all outta sight , the car is all pulled apart , doing the machine work now , I'll try to find some old mock up picks on the old 'puter
    cheers
    Steve in OZ
  19. tmacracin
    tmacracin
    I will do some measuring but I hope if I go 108" it will fit without a notch for the distributor. 108" will be good for the race track also
  20. twofosho
    twofosho
    I'm kicking the crossmember ahead in the frame enough to use a '36 spring in front of axle setup while keeping the wheelbase stock for full fenders, splash aprons, running boards, and bumpers. This makes room for my small block Ford (the flat motor I thought I was getting turned out to be frozen up) at the small cost of a shorter splash apron in front and longer struts to brace the radiator (no hood planned at present). Using a Model A yoke in the '36 wishbone will allow said wishbone to run to a crossmember between the front sump pan and the bellhousing. Mustang steering rack bolted to the axle completes the picture.
  21. VAPHEAD
    VAPHEAD
    Wanna do 108" ?
    the 2" won't be noticable with that motor.
    these all are at 106"
  22. Toqwik
    Toqwik
    You could always stretch it 4in and go with a spring in front. I am building mine 107 1/2 so I don't have to mess with the firewall. I'm 6'6" so I need all the room I can get. Also plan on running cross steer so you can get the column up higher off the floor.....
  23. Explain "steering rack bolted to the axle" ?
  24. tmacracin
    tmacracin
    Vaphead,
    I think 108" will look good also.Sent you a email
