Lost trunk key to my '49 buick
Discussion in 'The Hokey Ass Message Board' started by 12sec ss, Sep 27, 2009.
  1. 12sec ss
    12sec ss
    What are my options? Local locksmiths are pretty incompetent.. I tried takign door cylinders out and had keys made that work the doors now, they dont work on the trunk. Funny thing is that I only had 1 key for the car and it never opened the doors, just the trunk. I figured before something was wrong with the door cylinders but never got around to takign them apart, now i know why .. still kicking myself for loosing the key btw :(
  2. Antny
    Antny
    from Noo Yawk
    You're in Brooklyn. There are TONS of folks there that know how to pick a lock! :D J/K. Any competent locksmith should be able to pick it open, remove the cylinder and fab a key for you. Just a matter of finding one willing to do it.
  3. Wicked50
    Wicked50
    Use a screw driver
  4. lucky
    lucky
    take rear seat-back out of the car...climb through the opening(or get someone small enough to do so) and using some needle nose pliers, turn the post that is p***ing from the lock cylinder thru the latch itself...voila! trunk is open
  5. chaddilac
    chaddilac
    Pull the seat and crawl in from the back.... or knock out the lock... and shave the trunk!!:D
  6. 50stude p/u
    50stude p/u
    acetaline torch.
    wait, did you want your trunk lid? :D
    welcome by the way
  7. 12sec ss
    12sec ss
    I got the trunk opened, unbolted the latches through the back seat.. Took it to 4 locksmiths so far
  8. 12sec ss
    12sec ss
    you would think so.. i figured locksmiths down in coney island would be good, but aparently they specialize in the 80s cars, go figure :confused:
  9. fordcragar
    fordcragar
    from Yakima WA.
    Call a locksmith and tell them that you need a lock re-keyed and have them re-key it so it is the same as your doors.
  10. oilslinger53
    oilslinger53
    from covina CA
    Get out your yellow pages and call around. Let them know what you need, and that you can get blank keys if they can't. Someone will know what they're doing.
  11. Find a locksmith who's been in business for 40 years or better. Blank should be the same GM for all '66 and earlier cars. '70s AMC ignition may also work (I know the trunk blank is the same shaft as the older GM ignition. Makes you wonder how many AMCs could have been stolen when new with just a ring of junkyard GM keys).
  12. jamesgs4
    jamesgs4
    from denver
    use a wire wheel on a bench grinder and use it to "dull" your new key like it is worn out. the tumblers in the cylinder are worn and the new key isnt.
  13. 1lowbuick
    1lowbuick
    go to (old buick parts.com) and get all your key needs the web site ****s order the catalog :D
  14. Harry Bergeron
    Harry Bergeron
    from SoCal
    Old-time junkyards have huge rings of old keys hanging on the wall with no use for them any more. Find one that fits, they'll probably give it to you.
  15. ironandsteele
    ironandsteele
    i don't get why you don't think a locksmith could do it.
  16. thesupersized
    thesupersized
    does your glove box have a lock???????? that should use the same key as the trunk... bring that to locksmith
  17. Mr48chev
    Send it to me with a spare key that matches the door keys and I'll haul it to my locksmith who has never failed me on something like this. Under 10 bucks to have it done. I have no idea how many times they have made a key to match the tumbler or matched a tumbler to an existing key for me.
