Speedway Batwing warning
Discussion in 'The Hokey Ass Message Board' started by temper_mental, Sep 27, 2009.
  1. temper_mental
    temper_mental
    from Texas
    I do not want to start a thread bashing Speedway, I buy many parts from them, but if you are using the polished batwing (part number 916-35002) check the lower connection around the bung over.
    I was getting ready for a show this weekend and noticed that the lower connection around the bung had cracked all the way across on the bottom. Both left and right side were broken. This scared the **** out of me. I drive my coupe very hard when I am out. So look your part over and hopefully it's just a fluke.
  2. Ooof! That's spooky. Good thing you caught it and thanks for the heads-up!
  3. Unkl Ian
    Unkl Ian
    "Stainless"
  4. Unkl Ian
    Unkl Ian
  5. Ghost28
    Ghost28
    How old are those ?
  6. temper_mental
    temper_mental
    from Texas
    Around a year old.
  7. Ghost28
    Ghost28
    The reason I ask is I have a set of speedway mr roadster bat wings, and they have a lot more metal around the bottom where yours cracked and in there catalogue they show the heavier set like mine. Hmmm? John
    My part #was 91635006
    They don't even show your part# 91635002 any more or I just couldn't find it.
  8. 49 Custom
    49 Custom
    As I suspect most places do, Speedway distributes parts from many manufacturers. It's no excuse for defective parts, but it explains that while most of their components are just fine you have to be on the look out for lemons. Glad no one was hurt, and let us know how Speedway handles it if you contact them!
    -Stefan
  9. Deadbird
    Deadbird
  10. fastrnu
    fastrnu
    from shelton,wa
    Scarrrrrryyyyyyyy sounds like hydrogen embrittlement. not a good idea to chrome stressed parts. they need to be heat treated properly immediatly after chroming!
    Dont worry about bashing Speedway With the amount of outsourced **** they have taken to selling us I am outta there. Ask me about their Pertronix header kit sometime and their response WOW.
  11. Unkl Ian
    Unkl Ian
  12. Ghost28
    Ghost28
  13. sko_ford
    sko_ford
    they look very spindlely
  14. dino1
    dino1
    from austin tx
    looks like your wife almost owned Speedway....
  15. THR1LL3R
    THR1LL3R
    from St. Louis
    made in china?
  16. Dan Hay
    Dan Hay
    That would've been a nightmare down at the Texas mile!
  17. 32ratsass
    32ratsass
    Holy ****!!!!:eek: After you change your shorts, think very seriosly about the investment cast ones. Never had a problem with them! The ones that you broke, look scary to me before they broke. Glad you caught it before you had a major mishap!
  18. poofus1929
    poofus1929
    from So Cal
    That is just plain old scary. Good thing you caught that. Could've been disastrous.
  19. RAY With
    RAY With
    According to The Speedway catalog there sold under the Mr. Roadster name.I have a pair on my 33 Roadster thats been on for close to 2 years and no sign of fatigue or breakage.I will keep an eye on them and this could be an isolated case here. Thanks for posting the information and pictures.
  20. flatheadpete
    flatheadpete
    from Burton, MI
  21. jimi'shemi291
    jimi'shemi291
    Obviously, any load-bearing part "could" conceivably develop stress fatigue. But, shouldn't critical parts like this be going through a routine inspection process (meaning one of several reliable TESTS, e.g., sonic, magnaflux, x-ray, etc.)?
  22. HONESTHERMAN
    HONESTHERMAN
    From the close up pictures here. They look cheap and too light weight. I guess I would not have even put them on if they looked that bad when I first got them. But then it depends on how the company presents them. " Tested" etc.
    I sell stuff all the time and a lot of people only want to pay the "cheap junk price" for the good stuff. I do not sell anything that I would not use myself . Maybe the seller of this item should do the same. There ya go thats a polite way to say it.
  23. nailhead terry
    nailhead terry
    Man that looks like 1/8 steel that part in that stress load should at least be 1/4 inch thick and heliarced by a code welder not ho chi men !!
  24. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I sure would like to hear what speedway has to say about this..
    and would they switch out a set of those for the cast ones?
    as long as your front end is set up right..there should be no room for part failure like this, and owning up to it should not be an issue.
  25. Slag Kustom
    Slag Kustom
    i would like to know the rest of the suspension set up before jumping up and down about a part.
    4 link or hair pins
    tube axle or I beam
    spring location
    4t6ford likes this.
  26. Little Wing
    Little Wing
    from Northeast
    not for nothing ,but come on,,look at them ,,how thin they are,,all those welds..
    was a thread a while back talking about good built wings,,I picked me up a pair of these beasts good chunky
    also and not for nothing,,I see ohhhhh far to often on the site,," I need this part and I need it Cheap" and catalog buying most times that what you get and you get what you pay for,,
    I find it even sader that the people making these parts care even less as the make them and have the balls to actually sell this stuff to people...
    It may meet 'spec' but just barely,,thats a sad day
  27. zman
    zman
    from Garner, NC
    They're also well known for taking someone else's product and having it popped over in China.
  28. floored
    floored
    These appear to be the ones they are still selling on their polished 4 bar kits.
  29. You are one Lucky SOB, thats kinda scary.
    Looks like a spring over axle I beam to me. If so that part failure through poor quality manufacture, nothing to do with the front end set up!
    Yes, would love to hear what Speedway have to say!
    Doc.
  30. I found a crack in both of my bat-wings in the boss where the perch bolt goes through. Don't know who made em but both sides were broke. They were really cheap looking when I changed em out with the cast ones.:eek:
