60'-70's Vintage Oval Track Modifieds
Discussion in 'The Hokey Ass Message Board' started by john56h, Apr 11, 2007.
  1. George M.
    George M.
    The Woodchopper on Daytona Beach
  2. 34gasser-65AWB
    34gasser-65AWB
    Johnnyfast, I saw that posted here earlier. It does show how the upper tubes curl downwards at the shockmount and nerf-bar mount. Also shows the torsionbars quite well. Doesn't show much for the way the lower tubes (framerails) meet up with the curled-downwards upper bars or where the rear suspension attaches to the axle though. The wheels and brakes take priority in the illustration and overshadow the axle and suspension attachment point details.
  3. '54Caddy
    '54Caddy
    More from the great Jim Shampine, designer, builder, and driver. Inovator of the super modifieds that we see today.
  4. BKHRS
    BKHRS
    Last night there was a Vintage race at All American Speedway in Roseville, CA. There was one East Coast Modified and it was grouped with the super modifieds. The two best repaired were the 3 piloted to fame by Al Pombo and another the 6 which had been driven by Pombo at one time. The current driver of the 3 won the race, the driver of the 6 had been running the bottom all weekend (the designated line for the slow). He was gridded on the outside of the 92. It finally cooled just before the feature. Stuff happens!
    http://www.youtube.com/watch?v=dYE_cdzrvKg
    Barry
  5. nitram22
    nitram22
    Nice car!
  6. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Typically they would have used a live axle q/c. For that time period, the torsion arm would attach to the lower mount of a "birdcage" which held the axle brgs./caliper/ radius rod mounts. This was typical of about any open wheel car of the time, be it Edmunds, Nance, CAE etc.
  7. car toon
    car toon
    Dr. John, I love that injected #11! Thanks for posting that and for all your other contributions.....
  8. 34gasser-65AWB
    34gasser-65AWB
    Thank you very much Rootie! The pic of the bare frame sure does look to be an Edmunds frame to me; exactly what I was looking for! Thanx again for posting the pic, it's a big help.
  9. George M.
    George M.
    Frank "Mississippi" Curtis
    (from 3 Wides Picture Vault)
  10. yvan lacroix
    yvan lacroix
  11. BKHRS
    BKHRS
    Questions for you old school guys. I finally got a chance to look over the damage to the 92 car. The right side steering arm is bent. Is it repairable? Would heating it to orange reshaping it and letting it air cool be strong enough to race with? Any other suggestions? I'd rather repair it than replace it as long as it would be safe.
    Thanks, Barry
  12. Back in the day. steering arms were routinely bent to clear dropped axles. The arms on my car were done that way. The procedure was just as you described. Whether it would be strong enough for big tires and hot laps, you need to talk to some of the engineers on the HAMB.
  13. DICK SPADARO
    DICK SPADARO
    Been there done that. Heating and straightening the steering arm should pose no problem. Just do not over heat the metal. Before you attempt to heat the part and bend it back to its original shape check the opposite side for its corresponding angle or compare it to an original Ford spindle to determine the ackerman setting used on your car. Made many a web gusset to prevent this from happening, you might want to think about adding one too.
  14. George M.
    George M.
    Hey, Pete! Here's an oldie of a friend of ours!
  15. hahhahaha he looks like he matches his #..................12 lol
  16. retroridesbyrich
    retroridesbyrich
    from Central NC
    Yeah, and he has the same hair do! :D Oh wait, that's his helmet.
  17. We'd have it up and running again so we could qualify in the consi!!!!!!!
    Yes, heat it, bend it and let it air cool.
    We used to put a gusset on those arms so they wouldn't bend.
    AND.................. Be sure to check the king pin. Usually they will bend below the axle where the thrust bearing is. That'll put the steering in a bind. They are difficult to remove when bent. You may have to torch through the pin below the axle after you blow the thrust bearing out of the way. Then pound the pin down, cut it again and maybe again to get the spindle off.
    It's a lot of work, but otherwise you risk ruining the axle.
    We used to replace that thrust bearing with a solid piece of round stock with a hole for the king pin to p*** through. That supported the king pin and helped prevent it bending in that weak area. Ya' don't need the bearing when racing.
  18. George M.
    George M.
    Ed Garvin
    Ed Flemke
    Stan Disbrow
    Ray Brown
  19. Old School Brush
    Old School Brush
    Hello retroridesbyrich, yea it's me and I just introduced myself in the Introduction forum. Thanks for sending me a link to this site. This site is practically identical to another site I visit, so I already feel at home.
    I have a extensive album and additional pictures of vintage '70's & '80's Southern and Northern Modifieds that I have lettered or taken pictures of that I plan to share. Can't wait!
  20. neal78
    neal78
    Yvan: You probably know about CATAMOUNTSTADIUM.COM. But the owner--Bill posted that picture you did about that old racer that is being restored. It raced at THE PINE BOWL in N.Y. in it's day...thanks for all those great pics of REBEL SPEEDWAY too!! Neal
  21. retroridesbyrich
    retroridesbyrich
    from Central NC
    Hi Harold, welcome aboard! You must have shaved since the picture in your avatar was taken! :D
    Harold, for those of you that don't know him; is an expert sign painter and pinstriper, who's lettered more than a few Modifieds in his day. He does all the striping and lettering for me. He's a great guy, so Emil, go easy on him, despite the fact he's my friend.:eek:
  22. Well Harold, if you are a friend if Rich's, you don't stand a chance with me. LOL
    Welcome aboard. I'm just a lurker now, looking forward to seeing your offerings to the Mod Gods.
  23. retroridesbyrich
    retroridesbyrich
    from Central NC
    What? You ran out of colorful anecdotes?:D
  24. Old School Brush
    Old School Brush
    Sorry guys, but...........:rolleyes:
    A storm last night, even with computer off and unplugged caused my computer to crash. No hardware damage, just something in the software. Had to have Dell wipe out Windows XP and reinstall as if I just bought the machine today. Finally getting some of this stuff back and loaded.
    My loose misc. modified pics are at a vinyl sign shop of a guy who makes model car stuff and model decals and he is scanning/watermarking them to use to make decals for vintage models of the old Southern and Northern Modifieds from my pics. He is going to hook me up with his photo storage site to be able to copy and store/post these pictures when he finishes up, then I'll work on the pics in my album.
    I'll be checking in from time to time, so you won't think I've forgot about ya'll.
  25. George M.
    George M.
    "Steady" Eddie Flemke
  26. Yeah, we've heard THAT story before. Typical bench racing session.
  27. mike151
    mike151
    from conn.
    the # 47 in this post is driven by BIG EVIE PERICE. at Danbury
  28. George M.
    George M.
    Gary Winters
  29. Flyin'Brian12
    Flyin'Brian12
    Sonney Seamon, Lancaster,1972, photo by me.
