~ Help ~ Car only sputters doing left hand turns??
Discussion in 'The Hokey Ass Message Board' started by solo_909, Sep 27, 2009.
  1. solo_909
    solo_909
    Hey guys I have a 61 Ford Falcon And Im having some issues. For some reason my car sputters and lags when doing left hand turns only. I just replaced the fuel pump, Carb, spark plugs, condenser, rotor and rotor cap. We adjusted the timing and the carb but for some reason it's still having this problem when turning left! Can anyone help me out with an idea whats causing this? Thanks
  2. Rich Rogers
    Rich Rogers
    usually that means the float is too high but could also be a vac*** leak I think
  3. MarkzRodz
    MarkzRodz
  4. Did you replace your plug wires? I've had this problem before and I opened the hood out of frustration in the dark and it looked like an episode of Star Wars with all the sparks dancing around in there.
  5. da34guy
    da34guy
    Yepp , float.
    or Don't turn left:D
  6. solo_909
    solo_909
    Ok im pretty sure theres a vac*** leak and will have it checked tomorrow. How do I know if its the float? any way to check or test it?
    Been fulling around with the carb all day and after every adjustment taken it for a ride and the same thing Sputters on left hand turns. What should I adjust on the carb?
    Wires seemed to be fine no crystalization sp* and no pulse. Ill check it later tonight to double check.
  7. 68Caddy
    68Caddy
    these are all good answers. This is why the HAMB ROCKS!! i would change the wires first, wires can look good and actually be cracked everywhere.
  8. satan's childs
    satan's childs
  9. eddiescustoms
    eddiescustoms
    It's the float level or the float could be gas logged it might need to be replaced
  10. El Gordo
    El Gordo
    Two Wrongs don't make a Right - but Three Rights make a Left
  11. Spity
    Spity
    Dont just turn the screws on the carb on the out side, open it up and check inside. IE the floats.
    Or just make 3 right turns.
  12. solo_909
    solo_909
    how do I check the float? drop the tank?
  13. KJSR
    KJSR
    from Utah
    I think they are talking about the float in the carb......
  14. roughidle
    roughidle
    from iowa
    There's a float in the bowl of the carb. You need to find out what carb you have, what the float height should be. Then take the top of the carb off, check the float for defects, then set the height.
  15. solo_909
    solo_909
    O ok ill look into it But I have to say that I was having the same problem before swaping the new carb in.
  16. Thom Mead
    Thom Mead
    I had that problem once and it turned out to be the fuel outlet in the gas take itself! The tank had been built with the outlet too high. If the tank was 1/4 full or lower and I took a left hand turn the gas wasn't high enough in the tank to get pumped out and the motor stalled. I took the lazy man's way out and considered 1/4 full to be empty, kept more gas in it than that and it never stalled again. The car ended up being taken apart so it didn't become someone else's problem later.
  17. solo_909
    solo_909
    hmmm now that I think about it its below 1/4 tank and the more I drive the worse it gets on left turns. any fix for this? New tank? Thanks so much that would make a lot of sense
  18. Nitrid
    Nitrid
    from Kansas
    Ahahahahahahaaha
    Thanks for that.
  19. roughidle
    roughidle
    from iowa
    What do you have for a gas tank? Factory tank or something else?
  20. '54Caddy
    '54Caddy
    Put gas in it! j/k but seriosly i'd start there, go to the gas station and fill it up, if the problem stops then you know its your tank.
  21. solo_909
    solo_909
    Stock gas tank
    just got done filling it up and so far no sputtering. Ill be driving it more tomorrow so I cant say for sure but I think thats what is was.
  22. '54Caddy
    '54Caddy
    Good to hear! :) If theres one thing I've learned, it is never rule out the simple things. So many times there is a problem and we overlook the simple things it could be and end up spending more time or money trying to fix it. We've all done it and if there is anyone out there that says they haven't, then they haven't been working on cars for too long.
  23. solo_909
    solo_909
    Update! Bad News! It still does it. I filled it up and it seemed better but after driving around all day and down to 3/4 tank its still doing it when ever I make left hand turns. Where do I start now?
  24. american opel
    american opel
    from ohio
    if it didnt do it when it was totaly full say you have a problem with the pickup in the tank.does it have an electric fuel pump or mechanical?does it do it when you are sitting still{running and turn wheel?}maybe some wireing problem in coloum?
  25. Pitbullgoingpostal
    Pitbullgoingpostal
    I would have said carb float 10 times out of ten times asked, but you say you replaced the carb. Check the vent on the fuel tank. If you are turning left and it's clogging with fuel somehow, it could be vapor locking. I seriously doubt it though since the symptom briefly went away with a full tank of fuel.
    I'm ***uming your fuel line comes from the right, or p***enger, side. Since you are turning left when the problem exists, make sure your fuel line has not fallen down onto or into a suspension component causing it to be pinched. Check it all the way to tank. Follow it every inch.
  26. Customs&Color
    Customs&Color
    You might try checking the coil. I've heard stories of them going bad and not firing when making a turn. It was something about if they're mounted horizontal and the oil in them sloshes around in a turn. This has never happened to me before so I can say for sure, but it might be worth a try.
  27. carcrazyjohn
    carcrazyjohn
    from trevose pa
    How's your fuelpump ,lines ect .Do you have a power steering pump
  28. 1950merc
    1950merc
    from Butler, PA
    It's a long shot, but you may have a hole in your pickup tube. It would be like trying to **** soda through a bum straw. I have heard of this happening.
  29. dabirdguy
    dabirdguy
    I had this happen in my '85 Elky.
    Swapped carbs and motor and the issue ended.
    I'm STILL not sure what caused it.
    I suspected an electrical issue.
    Try putting an extra ground strap from the block to the ch***is.
  30. Nads
    Nads
    from Hypocrisy
    Too much fuel pressure, try a fuel pressure regulator. It did this on my 54 Chevy after I put in an electric fuel pump.
