How do you remove galvanizing?
Discussion in 'The Hokey Ass Message Board' started by Kerry, Apr 8, 2009.
  1. Kerry
    Kerry
    I've got some old style freeze plugs I'd like to use to cap the end of the digger rails but they are galvanized. What's a good wat to take the galvanizing off before I weld?
  2. hugh m
    hugh m
    from ct.
    Buff it off with a flapwheel. Don't know an easier way.
  3. 60'coupe
    60'coupe
    muriatic acid
    60'
  4. oilslinger53
    oilslinger53
    from covina CA
  5. G V Gordon
    G V Gordon
    from Enid OK
    Kerry, I don't know about Kansas but in Oklahoma the wind takes it off in big sheets.
    Gonna have the digger ready for this year?
  6. badger
    badger
    Wire wheel or brush has worked fine for me.
  7. rooman
    rooman
    60' has got it. I have used muriatic acid for years to remove cad plating, galv etc. Easy to get and very effective.
    Roo
  8. kraka138
    kraka138
    x2 on the wire wheel, should take more than that to take the galvanizing off, at least that's always worked for me
  9. alchemy
    alchemy
    But don't forget the 60 foot part. The fumes are killer, so give it plenty of distance.
  10. Deuce Daddy Don
    Deuce Daddy Don
    Quickest way is to grind off with co**** grinder wheel, grind down to "WHITE METAL" (past galv.) before trying to weld on material.-------------Don
  11. Hot Rod Bob
    Hot Rod Bob
    from T-ville Ky
    Works so you dont have to,brush on rinse off, but I'm lazy :D
  12. Kerry
    Kerry
    Muratic acid it is.
    Yeah George, I'm shooting for the HAMB drags this year. Time won't be the problem as much as $$$ or the lack of it.
    Gary Roushkolb has pretty much gotten the tig work done on it for me. I met him when I had him build the blower for the coupe. I'm taking the 6/71 for the digger to him this weekend. While The ch***is is at his place I'm going to have him make the seat for me too. He's a stand up guy and I'm learning a lot from him.
  13. hellonwheels
    hellonwheels
    from Bastrop
    EMS likes to galvanize their patch panels, so I end up sandblasting them with aluminum oxide. Keeps the panels nice and smooth, no s****es or wire wheel marks in the sheet metal.
    If your a fan of metal finishing, this works well. If your a fan of bondo, it hardly matters!
  14. MO_JUNK
    MO_JUNK
    from Rolla, Mo.
    Hi Kerry, I use store bought vinegar (acetic acid) to remove cad plating from hardware bolts that I want to paint. It works well. Just put your parts(freeze plugs) in some type of plastic or tupperware bowl and cover with vinegar. After 15 minutes or so you will see fine bubbles form on the parts and then small streams of bubbles will follow. I usually let it work overnight. Good luck, Sam
  15. Kerry
    Kerry
    Cool Sam. I've got plenty of vinegar left over from a de-rusting project. :)
  16. MO_JUNK
    MO_JUNK
    from Rolla, Mo.
    On another topic, how bad was it when you blew the coolant at the starting line (Hamb Drags) last year? Seems like I heard that the fan took out the radiator.
  17. Abomination
    Abomination
    Don't get any on ya! ;)
    If you try one in vinegar, and one in muratic acid just for science's sake, post us a couple of pics! :D
    ~Jason
  18. Vinegar and water !! Something smells Fishy here !! But it does work >>>>.
  19. Retro Jim
    Retro Jim
    I use a bench grinder with a wire wheel and works great . It's better & safer than muriatic acid but still work good too !
  20. Kerry
    Kerry
    Pretty bad. The 5/8" water pump shaft broke throwing the fan, clutch, and pulleys into the radiator. The lower blower pulley made sure it pushed the fan all the way through the radiator. The replacement radiator fit differently (closer to the engine) so I had to re-engineer the fan setup. Nothing to hard to do, just frustrating and $$$. Compared to this digger the $$$ was chump change though. This all adds up but I'm committed,... or maybe I should be. ;-)
  21. VonMoldy
    VonMoldy
    from UTARRGH!
    I would rather risk the fumes you can stand aways from it grinding off the plating you are going to be inhaling that junk!
  22. Fighter-of-Wars
    Fighter-of-Wars
    You can weld galvanized. We do it all the time with angle iron building little sheds for portable generators. Although, make sure if you do decide to do that, not to breath the fumes. Get some good fans blowing, and hold your breath till the smoke is all gone. Atleast, thats what we do.
  23. Fighter-of-Wars
    Fighter-of-Wars
  24. ems customer service
    ems auto does not galvanize our products, we use the same double side rust resisant steel as ford & gm use on the 2009 cars & trucks. grinding the our panels will only make them rust faster. this metal can be mig welded and spot welded just fine.
  25. MarkzRodz
    MarkzRodz
    VonMoldy is right!
    The Galvanizing is cancerous as all get out,
    don't breathe that scidt and keep skin exposure down too.
  26. spinout
    spinout
    from Dallas, TX
    Don't bring muriatic acid into your shop! Use it outside. The fumes will rust everything in sight. Don't ask how I know............
  27. Dale Fairfax
    Dale Fairfax
    I don't know if you're talking about O.E.M "freeze" plugs or not but if they are real Chevy plugs they are NOT galvanized. Rather they are "Terne Plate" or lead coated material-same as gas tanks. I remember from when I worked in material control at Chevy Mfg in Flint in 1960. In fact the part number for a "water jacket plug" was 838538.
    kidcampbell71 likes this.
  28. fiftyv8
    fiftyv8
    from CO & WA
    I am with Mark, yes it is dangerous and you can get poisoning from the fumes when welding. It does not take all that much to kill you out right.
    I have had the fume poisoning and I can tell you it is seriously no fun at all.
    I believe the grinding is possible the best of the worst solutions but use all the safety stuff.
    On large jobs they will use reverse electrolisis like rust or chrome removal since that is how it was put on first up.
  29. cilghal
    cilghal
    from ohio
    any acid or acid based cleaner soaked on it will do the trick.
  30. Kenneth S
    Kenneth S
    Caustic soda, long ago when I worked for redi-strip we had a big tank of caustic soda to remove paint, grease, etc from car bodies, engine blocks, etc. Caustic soda will remove the galvanize (along with aluminum, pewter, etc) without hurting the steel like acid does.
