SBC misses at idle and accelerating - need some help here
Discussion in 'The Hokey Ass Message Board' started by Kustomkarma, Sep 29, 2009.
  1. Kustomkarma
    Kustomkarma
    A friend of mine just picked up a car with a mild 350 Chevy in it. It has headers, electronic ignition, and a Carter AFB carb. It runs pretty well under load both at speed and idling. The problem is that it has a slight miss when sitting at a stoplight while in "Drive" and while accelerating off of idle. If she puts the car in "Neutral" while at the light, it smoothes out a bit. The car doesn't seem to do it right after it has been started, but the problem will start to occur after the car has been run 20 or 30 minutes. I'm thinking it's an ignition problem, but I have never had a car with a SBC as I've always run straight sixes. Anyone got any ideas? I'm hoping this is a common SBC problem.
    Thanks!
  2. miller
    miller
    from New Jersey
    how about va***e leaks?...check the head/intake area where the gasket goes..also check intake bolts may be loose?...Miller
  3. 38plymouth
    38plymouth
    Possibly EGR valve if its mid 70's up to late 80's.
  4. MIKE47
    MIKE47
    from new jersey
    Good start.
    I'd check for vacuum leaks. loose carb bases were common on q-jet carbs too. Then again so were worn throttle shafts. Use some carb cleaner and carefully squirt it around those areas. If the idle goes up, you found a leak. Just be careful with that stuff around ignition wires and exhaust parts.
  5. Tony
    Tony
    Have you guy's done anything yet like check the condition of the plugs, cap rotor, timing etc?
    Might be a good place to start if you havn't yet. Then at least you will know that the ignition parts are new, and the timing is where it needs to be.
    I have seen caps create idle issues similar to that as crazy as it may sound.
  6. Kustomkarma
    Kustomkarma
    I haven't really checked anything yet, as she just picked the car up like an hour or two ago. I'm already getting the semi-panicked phone calls as she's never had an older car before. All I really know right now is that the alternator and PS belt are loose. I'm going to pull the cap, rotor, and plugs and have a look. It's got aftermarket stuff on it, so it's possible it doesn't fit quite right. I've seen fancy wires and caps that look cool, but don't snap together too well. I'll check the EGR out too.
    Thanks for the replies.
  7. Kustomkarma
    Kustomkarma
    Anyone else got any ideas on what I should look for? I'm kinda surprised I didn't get more responses as this is only the most common Hot Rod engine in the Universe. :rolleyes:
  8. Obersten
    Obersten
    from Norway
    Too much vacuum advanced? Remove vacuum hose from distributer....
  9. onlychevrolets
    onlychevrolets
    sounds like its idleing fat....
  10. Shifty Shifterton
    Shifty Shifterton
    Your question doesn't require SBC knowledge, it requires tuning knowledge and the fact it's the most common engine in the universe doesn't mean much. If you know how to tune a straight six, you know how to tune a V8.
    Realistically until you check the condition of the ignition system and look for vacuum leaks as mentioned by previous posts, you're running in circles. Cover the basics first.
    Good luck
  11. noboD
    noboD
    Sounds like vacuum, either intake, carb or trans if old enough.
  12. Tony
    Tony
    Exactly. Seriously, you need to get a hands on look at what's what. The condition of the ignition system can tell you a lot. Once that area has been tended to if need be, and the problem still persists then you can dig deeper.
  13. LXTURBO2000
    LXTURBO2000
    from NEW MEXICO
    have you checked the spark plug wires?
  14. Doc Squat
    Doc Squat
    from tulsa, ok
    lxturbo2000 beat me to it. Check the wires.
    ___________________________________________________________________________
    Like I told the kid,"Your music's not too loud, it's just like OKC, it ****s!"
