What's the best hand cleaner
Discussion in 'The Hokey Ass Message Board' started by <FANG>, Oct 1, 2009.
  1. hotcoupe
    hotcoupe
    dawn dish soap and "golden fleece". i`ve been using this combo for thirty five years and my hands could p*** for surgeons hands. "golden fleece" is made by Chore Boy, no longer carried by the local grocery stores, i order it by the case online.
  2. Antny
    Antny
    from Noo Yawk
  3. bubba57
    bubba57
    from k
    The WORX. I get it from the Matco dealer is what I use at home. The uniform company supplies us with some that contains walnut shells that works great also.
  4. carcrazyjohn
    carcrazyjohn
    from trevose pa
    gasoline and keroscene followed by dishsoap
  5. LSGUN
    LSGUN
    from TX
    +1 for Fast Orange, I've used Gojo too it'll get the job done...
  6. poseur111
    poseur111
    I thought there would be alot more posts about pre-greasing your hands before you start working. If I know I'm gonna end up with the full black hand, I start by rubbing cleaner on my hands and just wiping it off with a towel: no water. Grease comes off a whole lot easier when it's all said and done.
  7. 29 de soto
    29 de soto
    someone finally mentioned cupran.it is the best i have used and there are good ones,but cupran will cut anything and is harmless.you almost feel guilty having soft hands when you clean up..so you might use a little lac. thinner after just to rough up your hands.
  8. 52pickup
    52pickup
    from Tucson, Az
    He's not ****ting you either, its amazing how much grease it'll wick out. My hands are heavily callused, particularly my finger tips and along the sides of my index fingers. The calluses on the sides of my index fingers are always have small cracks that are damn near impossible to get grime out of, but they are always spotless after I eat fried chicken.
  9. Xoot
    Xoot
    from PNW
    Didn't spot my favorite on the first five pages - Crisco shortening.
  10. Bosco1956
    Bosco1956
    from Jokelahoma
    I worked on big trucks doing brakes and the only thing that ever got my hands clean was Dawn.The scrubs worked well for me. I have used gas,oil,wd,brake clean,thinner. etc. I try to remember to put some gloves on but most of the time I forget about them.
  11. Boraxo. Just the thought of those 20 mules hauling it across 100 miles of Godforsaken Southern California desert makes me get all weird inside.
    Thanks, mules! Your stuff rocks!
  12. ShastaStyle
    ShastaStyle
    from Nor-Cal
    +1 for Lava soap. I still keep some goop around as well, but as someone else pointed out it doesn't seem to work as well as it once did.
  13. Chance it
    Chance it
    I just have to share this. Can't agree with the fried chicken grease option. I worked with a guy for years who ate fried chicken for lunch for sure 3 x's a week. His hands were covered with grease, he'd eat that damn chicken with the grease runnin down his hands, lickin his fingers after every bite & I know it didn't help remove that grease a bit. The finishing touch was when he'd pull his snot-rag out, open it up (sounded like velcro :eek:) wipe off his hands and put it back in his pocket. Now to be fair, I never could look after the snot-rag procedure but I don't believe it got the grease off either. OMG I'm getting a visual!!
  14. John356
    John356
    Stockhausen Kresto
  15. Mike51Merc
    Mike51Merc
    OK, I've used GoJo with and without pumice, Boraxo, Lava, the Orange stuff, Simple Green, WD-40, Gasoline, Kerosene, Liquid Dawn & just about everything else mentioned in this thread.
    But now I found what I call my "Magic Soap". I once grabbed a bar of my wife's Neutrogena glycerine soap (the clear see thru amber soap bar) and was amazed how it lifted the grease and grime without wrecking my skin like all the rest. It also smells sorta like my dad's old Brut after shave.
    I now buy the stuff at BJ's Wholesale Club by the box. You gotta try it.
  16. dirty old man
    dirty old man
    I've tried just about everythiung mentioned except that last post about Nutragena.
    But by far the best has been to wet my hands with water, pour in one palm a generous amount of Ajax Degreaser dish detergent and follow with a heavy sprinkle of Arm&Hammer Washing Soda. Rub in well and rinse. Best I've found in over 50 years of getting greasy. grimey hands.
    Dave
  17. BillM
    BillM
    At one time I had some waterless hand cleaner that had lost its gel texture and had gotten runny and watery. After searching on the net for hand cleaner recipes I found some with Boraxo laundry booster. Mixed some with the watery hand cleaner till it got nice and thick. It supercharged the hand cleaner and became my favorite. Its the best I have used so far. I think the recipe I found on the net used Murphy's Oil Soap with the Boraxo.
  18. southpark
    southpark
    what about softness? do any of these include some kind of lotion i have sentisve skin and cant have my hands all scratchy ill just never get my tampon in without scratching my inner thigh.
  19. 55driver
    55driver
    Permatex Ultra Cherry is my new favorite, works really well, is cheap,and the pumice isn't too harsh (greasy face).
  20. Xdrag48
    Xdrag48
    Snap-On! I have been using the Snap-On hand cleaner for several years now.It cost a little more but does a great job and wont dry out your hands like others do.I tried it once and was hooked....
    Steve
  21. turney33
    turney33
    from pasco,wa
    painter's partner! it's got warnings not to get it on your skin, thats the stuff for me!
  22. billsill45
    billsill45
    from SoCal
    In a pinch, mineral spirits, ATF or motor oil.
  23. uniquecoaches
    uniquecoaches
    I tried a new one from Advanced Auto and its called Jig-A-Clean and it works with out water and works quite well.
