Can someone fill me in on how come the new cars of today have so much horsepower for a medium displacement?? Years ago a 396 with a single 4 barrel had only 325 hp! alot but not alot for 1966.Now they have some v-6 jap motor & they say there 300HP!! new corvettes are 650HP!! Are they rating it differant? why so much now a days? JimV
Closer tolerances, Higher RPM, Higher compressions, computer controlled ignitions, variable timing, etc...
The way they were measured and reported then were different. Also, ow long ago was the 396 introduced? It can't compare to 6.0 or 7.0L GM LS1 or LS6. I have a 5.3L LS1 in my garage that after a cam,head, exhaust swap pulled at 441hp at 6,200 rpm. And thats from a 327 equivalent. Later it was upgraded with a new intake and throttlebody and picked up nearly 40 more HP.
Today's engines operate much more efficiently. All of the exotic parts we sought in the early seventies, high flow aluminum heads, light weight rotating ***emblies, high lift roller cams, etc. are common place on factory motors. Think about it. I have the hots to buy a GM LS7 engine for an off-topic car because of the sum of the parts. Aluminum block, CNC ported 12' heads, ***anium rods and valves, forged crank, dry sump oiling and fuel injection for ~12K. No way you could build this engine for this price 10 years ago and get a warranty to boot.
Yes,and the all aluminum engines weight about 400 pounds ready to go? I've heard the LS doesn't need a radial cam to make that power,very streetable.In a few more years it'll be the "SBC" of choice.
True, along with many years of engineering, newer technology with closer tolerances, upgrades in materials and processes, etc. The newer motors such as the GM LS motors turn more RPMs but driving them feels different to me. Don't get me wrong, they're powerful but they don't seem to have the off-idle hit that the older motors have. Just my opinion though.
That is true to some degree because of the computer engine management controls must deal with part throttle emissions.A non emissions LS will be different.
That's because of the computer controlled timing (advance/retard) sensors that relay the info back and forth, they idol smoother,..but don't be confused, they are very advance internally, exotic materials, roller cams, variable timing,.. ( but I'll stay with my large CFM.carbs, high lift thumpty-bumb cam shafts, and vibrate the pictures off the walls, when I leave at 7am. to go to car shows,...and I'll go ahead and pay for the terrible 'fuel-mileage' too,..) Because I love "OLD-SCHOOL" hotrods,..( but it is very 'humbling', to be "dusted" by a Z06, that idols like my pick-up truck,..Oh-Well,..I still laugh "all the way to the bank" mine is "Free-and-Clear" of payments, and "way-cheaper Insurance",... so that 'second' I loose in the 'quarter mile' is OK....)
Engine management, 40 more years of cylinder head development and better quality parts and machining.
What amazes me is the "High-compression rations" they utilize for supercharged applications,..( ZO6) and LS9's are very incredible; ( I really don't think they will last to the warrantee expiration though because of the "volitility"; and the "liability- disclaimers" in the "warrantee" completely get-around "spirited usages"...
I think that has a lot to do with it, but let's not overlook the other major advancements that have taken place. 1. Head design. Heads on new cars are light years ahead of what was on old motors. All the auto manufacturers have learned a lot about how to make heads work much more efficiently. 2. EFI. You can take even an old school motor and make it perform well when it is properly tuned for every given scenario. That's something that you will never get with a carburetor. 3. Much tighter tolerances and the ability to more accurately cast parts. I believe that the EPA and their stringent emissions laws forced the manufacturers to develop much of this stuff faster than they would have otherwise. I think we would have gotten here eventually even without the EPA's involvement but probably not at this rate.
I agree...my buddy has a LS1 camaro with big cam, forged HC pistons, headers, tune, and 150 shot that also hits a mean lick, runs 10.70s in the quarter on drag radials, and still gets 18 mpg though. Pretty appealing, no place in a hot rod IMO
A older slow Z06 Vette.Remember this vehicle has full emissions equipment,AC,and all that.Seems so non dramatic............Non traditional car and engine,but a nice motor never the less. http://www.youtube.com/watch?v=I6EiNFiLhV0
Back to one of the OPs questions, I am pretty sure they way the measure the HP from the factory is different today from back in the day. I think the 60s #s were done with no accessories (for a theoretical max HP), and I think the factory #s now are with accessories including emissions. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o> </o> I have been a big fan of the LS motors, I have a LS2 in my everyday corvette and I built the LS1 in my 50. After all the research to build my LS1 it is amazing on how advanced the LS1 motor is compared to the typical SBC. First and I think major point is the heads, they are something like 12deg heads vs the typ 23deg (I remember when the 18deg heads were the Sh!t). They have huge cathedral intake ports and are crazy efficient. Just look a stock LS1 head and compare it to a high end SBC race head and you will see that the LS1 is the way to go. Next is the block and tolerances, building it was not much different but everything stays where it belongs all the time. The LS1s have 6 bolt main (4 bolts and cross bolts in the side of the block). Add in the fact that they have roller cams and the computer it is amazing. <o> </o> They have crank triggers, cam sensors, MAP (manifold absolute pressure) sensors, air intake sensors (measures intake air temp), knock sensors, ETC all of which the computer is getting information from constantly as the engine runs. With this information the motor is always in tune no matter what. This is something that cannot be done with a typical carb and distributer. <o> </o> Think about this, there is probably more computing power in the modern car computer than is in the space shuttle.
The way horsepower is reported changed in 1972. Before then, it was gross brake horsepower, but '72 and newer are net brake horsepower. The difference is about a 23% reduction in rated horsepower, meaning a '66 325 horse 396 (the engine in my first car) would be only 250 horse using the rating system in place since 1972. That makes the horsepower figures in modern cars even more impressive, especially since the driveability is also greatly improved. Most of the responses to this have mentioned computers, and in my opinion that is the single most significant reason we're seeing the horsepower ratings as high as they are. Lots of sensors and an ECM that can make air/fuel adjustments instantaneously at every RPM, every atmospheric condition, etc, will make a more powerful, more fuel efficient, and even cleaner engine.
Thats where you are a 180 degrees backwards wrong on this. My buddy who owns a salvage yard is overflowing with the the 5.3L LS engines. He is selling them for 500 bucks a pop! You pick it out of a Suburban for 500 bones with the ECU and buy a harness for it for around 1,200 and get tuned properly with out touching a thing and keeping it all stock you have an engine that prices as follows. Engine 500 Harness 1,200 Tune 500 Total 2,200 bucks you have an engine that runs and will give you approx 20mpg on the hi-way.
If anyone gives a **** here is an excerpt from an article I wrote about the 5.3L engine. I wont mention the magazine name cause they **** balls. But the info is 100% accurate. I was there and did the project. In the 11 years since the LS-series of small-block Chevys was introduced, they have been factory-installed in everything from Corvettes to p***enger cars, trucks and SUVs. It's the latter that we want to focus our attention on in this article. A**** the advantages of these engines are factory aluminum heads, lightweight composite intakes and in some cases aluminum blocks. Many, such as the 5.3L (RPO LM7) have a cast-iron block with aluminum heads and composite intake. While the LS1 has received tons of attention, the 5.3L V-8 is of a lesser-known quan***y. Literally millions of these cast-iron 5.3s have seen service in vehicles like Suburbans and Silverados. For all practical purposes, the Gen III 5.3 is nearly equal to its older brother, the 5.7 LS1. In fact, the iron-block 5.3 can be bored out to 5.7, and any performance mod done to an LS1 can be done to the smaller 5.3. But that's not the purpose of this article. The goal here is to take a salvaged engine that is in good shape and add a few items to open up its nostrils so it can breathe a bit easier. We were curious to see what kind of power it would make in stock trim and then with aftermarket goodies-in this instance, heads and a cam. Before the engine even started, the OE computer has to be re-flashed to remove the vehicle anti-theft codes and other codes that will hinder the tuning. It turned out we ran into some problems with the ECM. The engine was originally a fly-by-wire setup and the ECM that came from the Suburban was programmed as such. After re-flashing the computer with the new engine tune, the ECM still resisted. After several hours of tuning and re-tuning, we went out and got another ECM that was set up for a vehicle with a cable-actuated throttle. Once that was done, the new ECM took the tune and ran beautifully. Fortunately, a friend nearby had a cable throttle body 5.3 with the ECM sitting in the back of a parts truck. That saved a little over $200 from having to go to a dealership and buy one. Once the engine was up and running properly, a pull was made using the factory tune. The engine pulled 344 hp at 5,000 rpm and 370 lb-ft of torque at 4,300. That's pretty impressive for a boneyard truck engine. After that, the ECM was flashed and another pull was made. This time the numbers were different: 357 hp at 5,400 rpm and 380 lb-ft at 4,300. Specs on the Stock 5.3L 5.3L Iron Block Years1999-2007 RPO #LM7 Displacement5.3 liters (325.2 ci) Bore3.780 Stroke 3.622 Compression9.5:1 5.3L Aluminum Cylinder heads Intake Ports200cc Exhaust Ports70cc Intake Valve1.89 Exhaust Valve1.55 Combustion Chamber61cc
I know it's not "traditional" and I'm not a "Vette-Guy" but John Lingenfelter was one of my favorite "Hot-Rodders"... and even he caved into turbo's eventually. I remember a Camaro/Firebird challenge back in the 90's with the LT1 engines... everyone had "supercharged" theirs... not John... his was a naturally aspirated "383" than ran close to or over 180mph and cleaned their clocks... they called foul though because he didn't have a catalytic converter on the car... he said "fine... I'll bolt on a converter and a supercharger and we'll REALLY see how badly I whoop your ***es"... or something like that. (Going purely off memory here) 0-200 in 16.23... on 93 Octane Yeah... the new stuff is great... but it'll never be like "hey open up the hood and let's take a peek" kinda' cool like the old engines again. Then again... that's why they make hood sides. Now back to your regularly scheduled programming...
I think if you put one of them giant fart can mufflers on you can pick up a few hundred HP just with that .
I daily drive a 2000 Z28 (LS1), I haven't done anything radical, long tube headers, no cats, true duals dumped before the rear end through an x-pipe and sweet thunder mufflers. Took all the EGR and AIR ******** off, it's a fun car. The LS engines have a very unique sound due to the firing order and the aluminum block *excluding 5.3, 6.0, etc.* so they tend to be raspy sounding at WOT. They have already became the "SBC", countless engine mounts for them, swap headers, stand alone systems, etc. They can make TONS of power for little money invested and they're reliable and get good mileage. So people are swapping them into anything and everything. I believe someone on here swapped a 5.3 into a '60 Cadillac? I have a buddy who recently ran a 11.2 in Hobbs NM al***ude with a '98 Trans Am 138k miles on the longblock, MS4 cam "239/242 .649" .609 111 LSA", factory 806 heads "the worst on an LS1 '98 only", headers, catback, 9" Moser rear end, six speed, 100 shot of nitrous and he can't drive. So he ran a low 11 with a tired 138k cam only LS1 and shot of juice at that high al***ude. If thats not impressive...
Arkiehotrods – your post above sums up what I was trying to say… Buick 59 – I agree with your points on a reasonable motor. I actually have a 6.0L and a 5.3 in the garage right now. They are reasonable, and a ton of parts are out there, oh by the way for my project I was able to get a harness and a computer already tuned for $600 (with you deal on the motors and my deal on a harness & computer someone could be running for $1,100
Well.....I'll bet the cars are catching up! Check out this article. http://www.popsci.com/node/31716 Enjoy!
OT/ I know - but that 5.3 iron block LS based motor is the best bang for the buck by far. The most widely installed engine makes it the most common and cheapest out of salvadge yards. rated @ 285 HP. & With a Cam, springs, headers and converter to match an other 100 plus hp is just too easy. Swapped one into a OT K-5 Blazer. The easiest way is to grab everything from the donor, from the fuel pump forward, complete motor, DBW gas pedal, trans, and front accessories, teed heater hose , harness and ECM. You can have the VATS only unlocked in the ecm for under 100.00 and run it as is or drop 500 for a tune that really wakes it up! The factory harness is pretty easy to make stand alone and into only a 4-5 wire hookup. Run a 04 vette fuel filter. Hint on harnesses (save a grand) is to get two damaged ones, they are next to zero dollars from the salvadge yard especially if they know ya!
