ID these: Spring perches,wishbone,tie rods,front suspension
Discussion in 'The Hokey Ass Message Board' started by thurstin, Oct 4, 2009.
  1. thurstin
    thurstin
    need your help on ID this front suspension.
    YEAR:
    Model:
    BOTTOM SIDE pics;
  2. DE SOTO
    DE SOTO
    '35-'36 Ford
    Cant Pin Point from your pics ... but its one of them years.
  3. Levis Classic
    Levis Classic
    The frame looks Model A
  4. R Pope
    R Pope
    Can't see the wheel pattern. '36 is wide 5, '35 is like most other Fords, 5X5 1/2.
  5. thurstin
    thurstin
    Thanks.
    The stud pattern is 5.5
    Thanks alot for the help.
  6. Rob Paul
    Rob Paul
  7. thurstin
    thurstin
    anyone have some extra spindle arms for this set up??
    as you can see,someone,at some point torched them off.:confused:
  8. pasadenahotrod
    pasadenahotrod
    from Texas
    Spindle arm eyes were probably cut off by another rodder to use in split wishbone brackets at the frame for the tie rod ends, OR, the front end was used on a trailer and then "rescued" but the ends were wrecked, OR, ...
