1964 Buick 300
Discussion in 'The Hokey Ass Message Board' started by SouthSideSlick, Oct 5, 2009.
  1. SouthSideSlick
    SouthSideSlick
    Anyone know anything about these? I'm considering trading for a project that has one. I'm not a Buick guy so any comments or thoughts are welcomed.
  2. squirrel
    we've talked about them here before I think....they're neat little engines, they use the "modern" BOP bellhousing so they'll bolt up to a bajillion GM transmissions.
    hint: to search for things like 300 that the hamb search might not find, use google and include the term jalopyjournal
  3. believe it or not, Wikipedia has a some good basics on it.
  4. 29 rattrap
    29 rattrap
    from New York
    i have one, not super interested in it so its just sitting in the corner of my garage
  5. rocket scientist
    rocket scientist
    300's are based on the all aluminum 215. Good news is that the 64's have aluminum heads with much bigger ports than the 215. They went to the cast iron heads in '65.(65-69 Corvair) valves which are oversized will fit without much effort. Even with the cast iron block, the 64 300's are light--weigh only about 400 lbs fully dressed. As someone else said, they have a common GM bolt pattern unlike the oddball 215. Tubular headers are available from the later Range Rovers that are finding their way into junkyards at this point.
  6. Hnstray
    Hnstray
    from Quincy, IL
    I think they are pretty neat engine........look like the bigger "nail valve" (i know,,I know everyone calls them "nail heads"........but they were FIRST known as nail heads because of the small valves looking like 'nails' )...but I digress.....what has been posted so far is correct. the heads did switch to iron in '65 and where changed in design for the 340 version in '66 and again in '68 for the 350. The aluminum 4 bbl intakes from '64 are (or used to be) sought after. I am putting a '67 340 with 'switch pitch' turbo 400 in my '54 GMC pickup project.........nuthin' wrong with SBC except they're everywhere......but here......
  7. J Man
    J Man
    from Angola, IN
    I think Enjenjo has one in a Buick wagon, hopefully he will chime in.
    Anyone know what hp these have stock and what you can get out of them?
  8. squirrel
    stock 210 hp for the 2bbl, 250 for the 4bbl.
  9. trad27
    trad27
    Im running a 1965 300 in my T, Good little engiens.
  10. d2_willys
    d2_willys
    from Kansas
    Lucky u! I want that SP400 so I can mount to 65 Buick 300, and put in older S10 4x4. THIS IS A TOP SECRET PROJECT!
  11. squirrel
    switch pitches are getting harder to find these days....glad I got a few back in the early 80s
  12. trad27
    trad27
  13. SouthSideSlick
    SouthSideSlick
    Thanks for all the feedback. I'd love to hear more if ya got it.
