Fix Your Temperature Gauge- EZ and It Really Works
Discussion in 'The Hokey Ass Message Board' started by 4woody, Dec 11, 2007.
  1. 4woody
    4woody
    I'm putting original instruments back in my '38 Chrysler.
    I found a set on nice-enough gauges, but as usual somebody had just clipped the tube for the "Bulb-and-Tube" (I think its called "Bourdon" type) temp gauge. This is the same type of system all the brands used to use, so this fix will work on Ford, Chevy, or whatever you have.
    I won't go into the step-by-step; you can read that all here:http://www.ply33.com/Repair/tempgauge
    I'll just tell you that it works exactly as described, and the whole process only took about 30 minutes.
    thebeebe5 and CoolYourJets like this.
  2. Awesome Tech!!!
    Thanks for posting this. I have always wondered what to do with these gauges!
  3. ChevyFastback
    ChevyFastback
    from Ohio
    Thanks for sharing this. I'm interested in retaining the original gauges on my chevy, but had concerns about the length of the tube on my temp gauge reaching the V8 vs. the original 6 cyl location. Nice. I'll definitely bookmark the site.
  4. 1931S/X
    1931S/X
    from nj
    hell yeah it works. found this link one here a while back and i did itto my 31 es***. i think it should be i nth etech archives if its not already.
  5. flt-blk
    flt-blk
    from IL
    I didn't realize you could replace a caiplary tube at home. I guess the ice bath is the trick, good to know.
  6. TWEKD1
    TWEKD1
    from chicago
    thank you in going to try and fix them myself!!! i will keep you informed
  7. 55 dude
    55 dude
    give yourself plenty of time with the capilary bulb in the ice. ether is some really bad ****.
  8. Petejoe
    Petejoe
    from Zoar, Ohio
    Its amazing the talent in this place.
    Great tech. thanks!
  9. 61bone
    61bone
    Wonder if maybe a little dry ice wouldn't be more effective.
  10. 4woody
    4woody
    I just used ice and salt like a hand crank ice cream maker. Never got so much as a whiff of ether, and the accuracy of my repaired gauge in the 180-212 degree range checks out well against a cooking thermometer.
  11. Shaggy
    Shaggy
    from Sultan, WA
    Wow good post
  12. FatFndr
    FatFndr
    My thanks to 4Woody for the shortcut to a useful article. I was looking at a very expensive repair.......with a little care, I should be able to do this at home.
  13. pdcooper
    pdcooper
    from Singapore
    Does anyone know where I can get a new tube and the liquid?
  14. Flat Ernie
    Flat Ernie
    Tech Editor
    The term "bourdon tube" actually refers to the movement in the gauge and is typically only used for pressure gauges. A bourdon tube is nothing more than a semi-flattened tube with one end crimped and the other end receiving pressure. Then the flattened end is rolled up like a snail. When you get pressure inside, the "snail" tries to unwind and moves the needle on the gauge itself.
  15. Looks like they just bought a cheap Sun mechanical gauge. If you look at the pictures it appears that is the case. Should be in stock at any larger national franchise auto parts store.
