54 chevy inline6 mounting brackets
Discussion in 'The Hokey Ass Message Board' started by thejim, Oct 8, 2009.
  1. thejim
    thejim
    from Wisconsin
    Does anyone know of a site on the net where i can get inline 6 mount brackets. Car has a v8 and am looking to go back to a 6 in it.
  2. InsaneEmpire909
    InsaneEmpire909
    from 909
    Call Todd at Waltons Fabrication (909) 931-9548 good quality parts and good pricing, also a nice upgrade for that inline would be a t5 or t6 ****** behind it. Todd sells everything to do the conversion let him know that Ryan recomended you. Thanks
  3. Snarl
    Snarl
    What engine?
    What transmission?
    Stock frame and suspension?
  4. 53sled
    53sled
    from KCMO
    use a 250 inliner and you don't have to change, or go with the 49-52 front / bellhousing mounts so you can run split fentons and let it breathe.
    55-57 mounted a similar way iirc
    Maybe hit up Waynes in Arizona? I think they have motor mounts for conversions to 58-62 style mounts
  5. thejim
    thejim
    from Wisconsin
    stock frame & suspension, has a turbo 350 ****** that i will keep in the car. looking to put a 250 or 292 in it. But i do have a 23?, can't remeber off hand, out of bro 66 malibu with under 10,000 miles.
  6. Snarl
    Snarl
    Both Tom Langdon and Ch***is Engineering have motor mounts for that engine in a 49-54 car.
    You may find in necessary to move the radiator forward, depending on where you ended up with the transmission location.
  7. Black Primer
    Black Primer
    Ch***is Engineering has them.
