Need some help Identifying this motor(buick??)
Discussion in 'The Hokey Ass Message Board' started by sauces62, Oct 17, 2009.
  1. sauces62
    sauces62
    from n.cal
    Found this at a garage sale and I think its a buick but dont know the year? Is it a nailhead. Check out the pictures... Thanks
      332.4 KB
      276.2 KB
      248.4 KB
  2. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    no, its not a Nailhead. Im not so sure that its buick either. Oldsmobile maybe?
  3. Henry Ford
    Henry Ford
    from USA
    That is a Buick 350, but not a nailhead.
  4. sauces62
    sauces62
    from n.cal
    What years did they make these.
  5. power58
    power58
    The last nail heads were in 1966 the distributor was in the back. The new design Buicks had the distributor and oil pump on the front of the engine starting in 1967 i believe. Not a bad engine. The Buick 350 had a good bore stoke ratio and good heads for the times. A 2bbl 350 from 67-70 was in the 260 HP range.
  6. sauces62
    sauces62
    from n.cal
    Well the guy ended up just giving it too me. He doesnt know anything about it it came in a camero his buddy bought a few years back. Free is always nice. ****** too. Thanks for the help guys.
  7. panic
    panic
    By "good", you mean small? Stroke is larger than the bore, worst of all the 350/360 engines.
  8. Retro Jim
    Retro Jim
    Good score . Looks real nice and clean too !
    The trans should be a 350 and I think that is a 1969-1970 something around there , Buick . They were quick engine too !
    Does it turn over at all or is it stuck ?
    RetroJim
  9. 61TBird
    61TBird
  10. robt500
    robt500
    from Lex, KY
    my buddy has 350 Buick in a '78 Electra. Doesn't set the world on fire but it's adequate. Hard to beat free!
  11. Buick sold that as a 340 in 66-67 possibly 68, so it's newer than that. They couldn't have been too bad, Jeep used them for a few years too.
  12. They're an ok engine.
    Easy to confuse with the 455 when doing the junkyard fandango.
    They come with T-350 trans.
    Speed equipment is limited to cams, a few intakes and I believe K-B used to make roller rockers for them.
    If it runs good as is, I'd run it and keep something else in mind for the future.
    Low volume makes goodies expensive.
    You can find more info on the Buick V8 board.
    v8buick.com
    Best way for quick ID between these and the big block 400-430-455 is to count the rocker cover bolts.
    Five on the big blocks.
    Six on the 350 I think, be careful here.
    One sure way is to look for 430 and 455 cast in 1" high numbers on top of the bellhousing area.
    I understand the 400 is also marked this way, but haven't seen a BB Buick 400 in person.
    455's also have cast in CID numbers upside down, about 3/4" high behind the starter.
  13. Brandy
    Brandy
    from Texas
    Just an FYI for that ONE DAY when you are given a free Nailhead (I'll pray for you), the heads sit straight up and down on the block, not at an angle. But anything that's free is certainly for me. :D
  14. Buick 350's are as close to bulletproof as you can get, and great torquers to get heavy cars moving. But other than that....
