s10 frame to shoebox swap vid
Discussion in 'The Hokey Ass Message Board' started by jpaull, Oct 17, 2009.
  1. jpaull
    jpaull
    I have a 6 minute vid I just put on youtube of me doing a s10 frame swap into a 49 ford 4 dr. I have alot of details in the video description that arnt in the vid. Just something i did to get a shoebox on the road for as cheap as possible
    http://www.youtube.com/watch?v=_kvMxmBc9uQ
    Jeff
    Kreepea_1 likes this.
  2. 55 dude
    55 dude
    thats pretty decent build for 3k! like the webber carb idea as that eliminates the computer. love a budget build.
  3. I Drag
    I Drag
    I can dig it.
  4. synthsis
    synthsis
    I like the water in the headlight.
  5. zman
    zman
    from Garner, NC
    You can't be serious with that notch. :eek:
  6. oldiron73
    oldiron73
    from WISCONSIN
    Nice job/It sounds nice at idle/dig the weber idea.......
  7. landseaandair
    landseaandair
    from phoenix
    That and where did the $40.00 worth of J-B Weld go?
  8. borndead327
    borndead327
    i agree with zman the notch looks a lil unsafe, you could have got a notch made for an s10 and cut a little out of the trunk and redo the sheetmetal
  9. MercMan1951
    MercMan1951
    He said that in the vid; that you could buy one, but he said he used what he had on hand... I agree though. Looks...'wimpy' for a notch.
    A+ for taking the time to make a vid and post it though.
  10. thirty7slammed
    thirty7slammed
    from earth
    I gotta agree with zman, frame looks pretty weak at that point especially with your shock mount aft of the notch. Other than that you did one hell of a job, she looks very cool.:D
  11. zman
    zman
    from Garner, NC
    even using what's at hand, he could of doubled up for the notch, but it really doesn't look like it'll be sufficient.
  12. Black Primer
    Black Primer
    Wow! Did you consider frame twist when you built that notch???
  13. Coulda saved a lot a dough by rolling on instead of spraying it.
    Love how you left the rad in so you could pry against it to get the motor out.
    Looks great, glad to see your out driving it.
  14. wetatt4u
    wetatt4u
    Hey jpaull,
    Thanks for the video ,cool little ride that you should really enjoy...
  15. plunger100
    plunger100
    great stuff don't let the nay sayers get you down ! your a man after my own heart i'm doing similiar thing with a 28 model a and a 88 s10 frame. lets hear it for the off the wall out of the box method grat stuff plunger100 aka jimmyfred
  16. zman
    zman
    from Garner, NC
    what do you mean? build something that is unsafe and it's alright? I think not. That part of the frame needs to be beefed up, period.
  17. lorodz
    lorodz
    looks cool ..saved alot of money ..and he is driveing it ...3 grand ..good job....c notch is a little scary
  18. garagerods
    garagerods
    from Omaha
    Great job!!
    You may want to beef up the "C"......but....if the notch gives way then you'll have an awsome TAILDRAGGER!!!
    But I'd fix it.
    The fact that you built it at that level with that amount of money speaks volumes.
    Great job!
  19. PAUCHO
    PAUCHO
    Thanks for the vid......I think it's a cool way to go on a tight budget.....The car looks like it has some power, and would be fun to drive with good suspension and the 5 speed......after all the work you did, I think beefing up the notch would be no big deal for you with your skills.......Cool car......Have fun.....
  20. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    I cant see the video (running an old OS on my computer temporarily) but from that screen shot the C looks scary, frame rails get their strength from sidewall height nearly exclusively, and that is pushing metals limits of liability to a dangerous level. I cant wait to see the vid tho, I want to see how its done and how it sits on the S10 frame, I know the subframes seem to fit really well. Best of luck with the project.
  21. Tom$lick
    Tom$lick
    from Kansas
    An error occurred please try again later...
    Updating the vid?
  22. southpark
    southpark
    micky mouse build the frame?
  23. elrobo818
    elrobo818
    looks good man. thnx for sharing.
  24. I agree with everyone on the C-notch! Beef that ****er up!
  25. jpaull
    jpaull
    It filled the trim holes and some rust holes lol
  26. jpaull
    jpaull
    After reading your post, I realized the video didnt show the top of the C notch for anyone to see what it was made of. The top of the C Notch has TWO 1 inch pieces of thickwall box tubing welded together side by side. From the side it looks thin. I went outside, pulled the wheel off, and took a picture of it to clarify. it actually has MORE metal and strength then any C Notch you can buy. If i would have seen this view only from the side, i would have thought the same thing though.
  27. zman
    zman
    from Garner, NC
    Sorry, it still doesn't cut it. The structural strength side to side may be adequate. But it needs more structure height wise.
    That explains so much. Why not do it right?
  28. J'st Wandering
    J'st Wandering
    Thanks for the vid. Keep us informed on how the c-notch holds up. I am curious. I have a tendancy to over build.
    Neal
  29. I Drag
    I Drag
    I think your notch is fine, especially with the double thickness of tubing. Stock S-10 frames are pretty flimsy in that area, what you have is way stronger than stock. Bolting the frame to the body stiffens the whole thing up.
    If that's going to break, it will be the S-10 frame part right next to your welds.
  30. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    I agree completely. Just saw the video though, that little car is bad*** man! That is really using what you have and making a daily driver that wont kill you at the gas station.
    As for the bodywork, yes, you shouldnt use JB weld, but its a four door shoebox that most likely nobody else was going to touch, who friggin cares. Just make it safe and enjoy it!
