i picked this holley mag/dist the other day?what is it for?anybody know/???????ideas?tractor?it has oil inlet outlets as well??????
No doubt I will be tagged as being a ass, but the little tag with the numbers on it that we can't read from the photo are probably a good point to start from. You have a model number and a part number. Holley is still in business... The fittings are probably for oil lines?
http://www.google.de/patents?id=7qF...rce=gbs_overview_r&cad=0#v=onepage&q=&f=false http://www.google.de/patents?id=Imd...rce=gbs_overview_r&cad=0#v=onepage&q=&f=false Not the whole story, but a good start.
The safety wire could be air craft or military ,but my best guess is an ice cream blender less the prop .... or im just hungry .
Says clearly on the side: Part No: *-719 Model: 1255 Eng. Mfg. No: 48312 Holley Carb Co. To me that's all you need to know to find the info. (* means can't read the first number)
Those aren't oil fittings, they are vacuum ports for a vacuum governor. They go to a diaphragm on the carb. There's a centrifugal setup in the bottom part of the dist. Common on big gas engined trucks.
I have a '58 International V220 dump truck with a 549 International gas job. The 549 is a V8, but it does have a Holley distributor very similar to yours. I'll check the part numbers later. Governors' were typically mech. wired so that drivers could not tamper with them and over run the motor.
