Taking apart a 44 year old truck
Discussion in 'The Hokey Ass Message Board' started by neverliftmotorsports, Oct 18, 2009.
  1. neverliftmotorsports
    Man this is turning out to be a lot more fun than I was hoping for.:rolleyes: Most of the damn nuts are spinning in the holders with almost no way to get to them. Im thinking about cutting the heads of the bolts off and just order new ones. Oh yeah its a 1965 ford f100. Im trying to get the grill off. A couple of them I was able to get some vise grips on some but the bottom bolts are hidden perty good. Any ideas?
  2. FiddyFour
    FiddyFour
    dont use a torch... bad medicine there... use an air cutoff wheel and go slow. bolts are cheap, tin/trim is not...
  3. neverliftmotorsports
    Yeah i did think about the torch but too much around the bolts I want to keep.
  4. squirrel
    working on a late model eh?
  5. neverliftmotorsports
    I want an older truck like a 36 ford or something like that. But my dad had this sitting at my grandmas house for 10 years so I took it. Im going to slam it and clean it up. My dad still thinks its his but there is no way. Im going to use it to tow my 65 falcon wagon.
  6. LarzBahrs
    LarzBahrs
    from Sacramento
    Putting some astro supremes on it or some cragars with redlines?
  7. neverliftmotorsports
    That would be cool. I think im going to put some 10" wide steels with chrome rings and caps. I want to paint it semi gloss copper orange. With some kind of scallops. I dont know what color wheels Oh and 3 inch white walls.
  8. neverliftmotorsports
    Im keeping the 240ci with the 3 on the tree in it. With stock interior.
  9. hopped up
    hopped up
    from So Cal
    I grinded or cut all the stubborn bolts that were giveing me a hard time.You then need to go out to orchards, or what ever hardware store and buy nuts and bolts, fender washers. I bought them in bulk. Even if you dont use them then, you will later. Neve use old nuts and bolts, In my advice.
  10. neverliftmotorsports
    I would like to put stock bolts and those stupid nuts with the holders back in.
  11. RodStRace
    RodStRace
    Soak everything you are planning on touching for at least a week. Go out every couple days and soak....
    If they fight you coming off (commonly caused by rust on the exposed threads), Tighten them. This will snap off the bolt and you will have to remove the broken shank and nut after. Don't do this on blind stuff, just what you can reach.
  12. My advice whenever starting a new project. Buy a few cans of WD-40 carefully go around the entire vehicle spray the front and rear of ALL bolts/nuts careful not to overspray any plastic or painted areas you don't want to stain or interior parts you aren't going to replace then be patient wait a week or so go back and small wire brush all the rust the wd-40 loosened up especially the threaded area re wd-40 again and then start to dissasemble this gives you a chance to look over the vehicle and any problem areas ,special tools you may need swivels ect and saves tons of time trying to remove busted bolts and saves big money in bandaids and saves on sore knuckles too!!
  13. tommy
    tommy
    If you can get to the cage nuts, vise grips can sometimes get enough clamping power so that a wrench on the bolt can break them loose. Often they are not that badly frozen. It's just that the cages are rusty too and become the weak link. New cage nuts are available to tack weld in place for re***embly.
  14. 30dodge
    30dodge
    from Pahrump nv
    IF YOU USE A TORCH JUST USE IT TO HEAT THE NUTS AND BOLTS,then spay with oil , cool , wrench
  15. FiddyFour
    FiddyFour
    yea, i gotta say one last time...
    old hardware is not worth the trouble. use new. the goofy "nutclips" are available from dennis carpenter and they arent that spendy. bolts are also cheap. use new stuff... it'll look better and guaranteed to come apart if you need to work on something in 6 months
  16. neverliftmotorsports
    The thing that ****s is that the only ones messing up are the ones that you cant get to the back. Or I would would put vise grips on the back.
  17. dotcentral
    dotcentral
    I went through the same thing last year on my 66. Just takes patience. Like is being said, spray them with penetrant and let soak, trying tightening before loosening, look for creative ways to access the nut clips. I sometimes smack them with a hammer or wrench, supposed to help the penetrant soack into the threads. I broke a lot of fasteners. Was able to grind some off, drill some out, etc.
    There are cheaper places than Dennis Carpenter or autozone for replacement hardware. I got some of my new hardware from an automotive trim supply house. An old place in a rundown part of town. Some autobody supply places carry this stuff also.
  18. neverliftmotorsports
    Thanks for the help I just hope I wont be taking it apart again soon onec I get it back together.
  19. CShroom
    CShroom
    OK, I had the same problem except on a 50 year old Ford. I did use a torch, but not Oxy-Acetylene. Instead I used a propane torch and heat cycled them a few times, things came out a whole lot better after that. Just don't sit on them too long, just long enough to get them hot, let them cool, heat them again, cool and try to break them free. If it doesn't work, try the process again.
  20. Merlin
    Merlin
    from Inman, SC
    The same thing happened on my 54, An air cutoff wheel is your friend.
  21. 64Cyclone
    64Cyclone
    I've found that "In-Force" by BG Products is very helpful. Just spray and let sit overnight.....and usually they come loose.
  22. neverliftmotorsports
    I havent had any problems with them breaking just then nut clips messing up and the nut breaking from the clip and not being able to get to the back of them.
