Anyone know where I can find a diagram on how the gl*** goes back in, along with the parts needed. I wasn't around during the removal process, any help would be appreciated!
Are you talking windshield and back gl***?? If so, and your inexperienced with installing gl***, call a good gl*** company (a reputable body shop will know the best in your area) and have them install it for you.
For front and rear gl*** you just buy the rubber molding and wrap it around the gl***. theres a groove youll see on the rubber mold. spray soap water on rubber mold and where gl*** is going to sit. Use a string to wrap inside and around the mold groove that goes inside the car, lay gl*** in area, from inside the car gently start pulling the string towards you until the gl*** slips in. You want to have the string start from the upper middle of gl*** by rear view mirror and work your way down and around gently. Old gl*** sometimes doesnt slip in to well and sometimes breaks on corners - front gl***. This works on Chevys all the way up to 64 Impalas.
