I have a 41 rear and there are extra holes in the spring perches right next to the shackle pins does any body have pic's of what these are for
Rob, As stated they are for the shock link that connects to the hydraulic shock mounted on the bottom of the frame rail. Are you going to be using this rear in your build ? 41 Dave
I planned on useing just the center section and axles and changeing the axle houseings /torque/driveshaft /bones to a 37-40 the 41 has the longer torque tube and shorter bones
