The Inline Modified version 2.0
Discussion in 'The Hokey Ass Message Board' started by Empire32, Feb 5, 2009.
  1. Hellfish
    Hellfish
  2. freebird101
    freebird101
  3. mrdodge
    mrdodge
    Awesome project. Looks great. Time to get back to the garage........
  4. KUZTOM
    KUZTOM
    AGAIN , looks good, nice job on the spring perch's......
  5. holeshot
    holeshot
    from Waxahachie
    hey Empire32... thats 1 unique little rod, i like it. 6 cyl. chevys are damned good engines. so good in fact that TOYOTA coppied them in the 50s. did you know that? not many people do! your new friend in texas U.S.A. call me POP..are old FART! HA!
  6. AnimalAin
    AnimalAin
    I remain inspired by this project.
    Your bench seat will be much more comfortable if you cut holes in the base where your bottom rests, and cover the opening with woven straps. I'm sure you can find a how-to somewhere on the HAMB. I know this from personal experience; makes a world of difference.
  7. Empire32
    Empire32
    from FRANCE
    thanks for the tip !
  8. striper
    striper
    I did this and with 2" of foam it is like a Cadillac. When I get the final upholstery done I'll probably reduce the foam to 1". Very comfy. Oh, and make sure you get some support under your legs at the front of the seat.
    Pete
  9. stealthcruiser
    stealthcruiser
    I like it , Etienne...............Damn neat build ya' got going there......
  10. Empire32
    Empire32
    from FRANCE
    Some work those days:
    No pictures: rear brakes rebuilt, front end finished (new kingpins, nuts & bolts), added some more rivets in the frame.
    With pictures: rear lever shocks from an english car (need now to do the brackets on the rear end)
    Alternator bracket done (will be a generator later)
    also a bracket for the clutch system.
    and done some engine turned aluminium experimentations...
  11. Empire32
    Empire32
    from FRANCE
    Last update (sorry no pictures)
    everything is parted out, and the final welds of frame will be done soon. After that, I will built the stuff again and finish lots of stuff, making brake lines, fuel line, exhaust, etc..
    I hope to make a first road test the next spring/summer !
  12. Empire32
    Empire32
    from FRANCE
    Some boxing work on the frame yesterday. Final welding coming soon..
  13. Mart
    Mart
    Interesting bracing inside the channel. Never saw that done before. Are you a bridge engineer??!!
    Keep up the good work.
    Mart.
  14. Empire32
    Empire32
    from FRANCE
  15. Little Terry
    Little Terry
    I really like what you are doing here. It gives me inspiration to use my 292 for something. Please keep the updates coming.
    Mark.
  16. greasemonkey060
    greasemonkey060
    I love this build. I just picked up the front half of a 27 touring. And this build has been alot of motivation! Keep up the good work!!
  17. Empire32
    Empire32
    from FRANCE
    Thanks
    I will be busy with my job in the next weeks, so, expect more updates in january...
  18. Empire32
    Empire32
    from FRANCE
    I fund some time yesterday to work a little bit on the modified.
    All the boxing plates are cut & tacked, and, after the pictures, 50% of the welds was done.
  19. Pauly da mick
    Pauly da mick
  20. James D
    James D
    Cool little project. Different
  21. striper
    striper
  22. freebird101
    freebird101
    nice build, keep it up
  23. 41 Dave
    41 Dave
    Etienne, Looks like you made some great progress. Looking forward to your report when you make that first cruise !
    41 Dave
  24. Empire32
    Empire32
    from FRANCE
    Thanks !
    I Hope to do the first test dive this spring/summer !
  25. Empire32
    Empire32
    from FRANCE
    i've worked yesterday.
    The welding work is now done, and grinding on progress...next step, some paint..
  26. Empire32
    Empire32
    from FRANCE
    at least, some progress !
    Frame is welded and grinded, painted, and steering, front & rear ends, are back !
  27. 33-Chevy
    33-Chevy
    A really beautiful job. I like it.
  28. Empire32
    Empire32
    from FRANCE
    some progress...
    battery "box"
    rear shocks and links, crossmember gussets.
    engine & body back on the ch***is as well as other details
    next steps: fluids lines, E break system, shifter, and lots of more...
  29. James D
    James D
  30. charleyw
    charleyw
