Bonneville styled 1932 tudor build
Discussion in 'The Hokey Ass Message Board' started by Salt Flats Speed Shop, Oct 17, 2009.
  1. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
    PERFECT!!! got the stance, the chop - i dig it!
  2. Salt Flats Speed Shop
    from Utah
    I re-did the pictures to get them more accurate. I added pictures of adding in the roof as well as leaning the posts. Part of me wants to just add in the roof and be done with it. But if it really helps the look, im not opposed to take all the insane work involved in leaning the cowl. Just not sure if when its done you will be able to see a huge difference leaning the posts. See what you guys think. I defiantly want your guys opinions.
  3. Mat Thrasher
    Mat Thrasher
    I say 5-1/2 straight chop and lean the posts. I think the car has enough rake in the ch***is. The slanted chop makes it look a little off.
  4. 60'shotrod
    60'shotrod
    Damn that Sedan is gonna be SWEET,all those Photo-chops confused the **** outta me, which ever way you go you CAN'T go wrong!
    Nick.
  5. HotRodFreak
    HotRodFreak
    I vote for 6" all the way except only slice 4" from rear window.
  6. sgarofalo
    sgarofalo
    from USA
    I say 4 1/2 straight, lean posts, push that front axle forward. 2cents
  7. metalman
    metalman
    Man, do you ever sleep?
    I'd vote for the even cut, IMHO to easy to get the side windows looking "odd" with the angle cut. You could always do the angle cut, tack it together and roll it out and see if you like it, better the real deal then photoshop. Be easy enough to cut a little more out of the back till it looks good. No on leaning the cowl, been there, done that and your right, insane amout of work, not worth it in the end.
  8. Beef Stew
    Beef Stew
    from So Cal
    opps, meant bobbed. don't know what ****ed would be but it sounds gross.
  9. Southfork
    Southfork
    I'm going to have to come over to your shop and take a look at this. I like the 5.5 straight across with leaned posts best, Chris, but on my own Tudor I will likely add to the roof rather than lean the posts. It's an awful lot of work to lean the A pillars.
  10. solid
    solid
    Wedge chop w/ a-pillars left alone...
  11. hdgarcia
    hdgarcia
    from Houston
    Great lookin project,
    Here is a pic of my ch***is with a similar front set up. Bobbed and notched horns a flat front cross member and posies springs with a stock ford axle.
    It started with a drop axle but the set up was too low for what I was goin for and required the tie rod to run through the engine compartment.
    Where will you run your tie rod?
    I vote for the 4.5 to 5.5 chop with the leaned back A pillars
    -yogi
      134.9 KB
      140.1 KB
    AHotRod likes this.
  12. Salt Flats Speed Shop
    from Utah
    I got started today on getting the rails locked into the frame jig. I'm almost ready to start putting in the boxing plates.
    I wanted to have something on paper that I could reference to. So I took a stock drawing of a 32 frame and modified it to what I am doing on mine. That way I had exact measurements of the frame front to back, including the pinch and bob.
  13. hiboy32
    hiboy32
    from Omaha, NE
    You might want to put a patent on those frame diminsions so people dont try to just copy them
  14. Salt Flats Speed Shop
    from Utah
    I'm not to worried. The front part of the frame is the only section that I altered. And my setup with the springin the wishbones is all by its self anyway with how it is measured from the axle. Plus I'm not the first person to do what I'm doing :) its not a bad idea though.
  15. robt500
    robt500
    from Lex, KY
    I own the patent on that frame design. My attorney will make contact.
  16. Salt Flats Speed Shop
    from Utah
    I got the firewall hood and grill mocked up. I'm borrowing a original radiator from a buddy. Its resting right on top of the axle and the grill still needs to come down a little bit for everything to line up. Ill have to get a radiator that is at least 3" shorter.
  17. tinmann
    tinmann
    Nice progress on a visionary project. You keep updating, I'll keep checking back.
  18. robt500
    robt500
    from Lex, KY
  19. Nice, really thinking about a sedan for my next project - going to keep an eye on this one!
  20. scotti32
    scotti32
    Man, this tudor is goin to be *****in', can't wait to see it progress.
  21. Retroline
    Retroline
    Great proportions. This will look killer, keep it updated please.
  22. ROBERT JAM
    ROBERT JAM
    Any thing new going on with this project? Keep posting the pics and progress.Sedans get my attention!!!!
  23. Salt Flats Speed Shop
    from Utah
    Just getting things ready to work on it again this Saturday. I need to get the spacer blocks that locate the boxing places cut up and ready to go. I only get some evenings and Saturdays to work on my projects :)
  24. 51Gringo
    51Gringo
    from Nor Cal
    I can completely understand!!! and relate, btw the stance on that first pic you posted of the 5w is *****in, where's that one?
    Max.
  25. Salt Flats Speed Shop
    from Utah
    Im not sure where I got that picture of the 5 window? Ive had it for a long time though, and its always been in the back of my mind to do something similar.
  26. Salt Flats Speed Shop
    from Utah
    I got the rear model a crossmember welded in place. And I got all the spacer/body mount blocks welded in place as well.
    Now I need to build the front crossmember, mount the wishbones, and I can put in the boxing plates.
  27. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I have a Model A crossmember that I want to replace the round member with on my Ionia frame. I just need to aquire the skill and sand to do so.
    Looking good!!!
  28. 3wLarry
    3wLarry
    from Owasso, Ok
    Where did you find those cool-*** rear tires?
    kidcampbell71 likes this.
  29. Salt Flats Speed Shop
    from Utah
    I got them at the L.A. Roadster Show this year. Im thinking they are probably 50's-60's firestones that have been grooved.
  30. Salt Flats Speed Shop
    from Utah
    I got the wishbones mounted tonight. Im trying to decide what im doing on the front spring. I'll have the spring mounted in the wishbones, I just am trying to figure out how I want to mount the spring cause I want it to sit as low as I can get it. That way I can keep the crossmember as flat as possible.
