Did i get it right this time??(stance)
Discussion in 'The Hokey Ass Message Board' started by BBobb, Oct 23, 2009.
  1. BBobb
    BBobb
    For the last few months i have been making changes all the way from Posie springs to lowering blocks and more to try to get the right stance i could live with,kind of like trying to find an electrical short.Here's what i finally came up with.OPINIONS BOTH POSITIVE OR NEGITIVE WOULD BE APPRECIATED....
    Upfront thanks
  2. Bent
    Bent
    from Canada
    Close. Back needs to come down just a bit more. Looking good otherwise!
  3. brigrat
    brigrat
    from Wa.St.
    2" lower in front, 3" in the rear......................
  4. pasadenahotrod
    pasadenahotrod
    from Texas
    Next time take the picture from the sunny side. Can't even see the wheel openings in the black fenders around the back tires in the black shade.
  5. robert56
    robert56
    looks like the rear could come down a few more inches. And you could step up the front tire diameter - it looks a bit lost in there. I like the look of 6.50X16's all the way around- but maybe I'm biased (get it? - biased!):p
      370.3 KB
  6. Von Rigg Fink
    Von Rigg Fink
    from Garage
    down a bit in the rear at least
  7. IMO, it's not just the height, but how well the tires fill up the wheel-wells. It's a combination of both. You'd be surprised how taller tires can affect the look. (easy for me to spend your money!)...:D I believe it's more important than the actual height. Super-low is not necessary or even desirable sometimes. It is a truck. Granted, a little lower might be good, but if you plan on really driving it a lot, and even loading the bed sometimes, you have to consider the practical aspect. Good luck. -- Rick
  8. BBobb
    BBobb
  9. pasadenahotrod
    pasadenahotrod
    from Texas
    Again no definition where it counts.
  10. 40FORDPU
    40FORDPU
    1''-2" FRONT 2"-3" REAR The rake looks good though. Nice looking pickup.
  11. Roostre
    Roostre
    Well I should probably apply Lesson #1, but f#@& it.
    Looks about perfect to me... I like the back of a truck to be up just enough to let you know that it could still haul a load if it wanted to.
  12. BBobb
    BBobb
    I am generally concerned about dropping the rear much more,it's my shop truck and i have installed a reese hitch on her to haul my Model A around to all the car events.If i drop much it will look like the V emblem on a caddilac between the trailer and the truck
    Wish i could clone my fat *** so i could drive them both
  13. chevymike
    chevymike
    Okay, now turn the truck 90* so the sun is actually hitting the side of the truck, which helps to highlight the wheel well area.
    Overall the truck looks great but agree, I think it needs to come down a little more, maybe 1" front, 2" rear. Still would have a slight rake to it but gets the tires to fill the wheel wells a little more.
    OR, you could say the hell with it and just drive the SOB. Again, Nice Ride!
  14. BBobb
    BBobb
    I have a stock axle wit a posies reverse spring in the front. What route could i go at this point to lower her more in the front.The rear is no problem,I could simply install smaller blocks
  15. Jalopy Joker
    Jalopy Joker
    Hey, it looks cool-drive it. If you want the perfect stance put in all new suspension with air bags, etc.
  16. Von Rigg Fink
    Von Rigg Fink
    from Garage
    if your going to tow with it..I'd leave it there
  17. dickster27
    dickster27
    from Texas
    Brian, it looks just fine the way it is. Buddy, you know you will never please everyone so do the next best thing......PLEASE YOURSELF.
  18. pasadenahotrod
    pasadenahotrod
    from Texas
    Wait until 2-3-4 O'clock when the sun angle is a little lower in the sky. Park the truck side-on to the sun and take the picture from the bright side.
    Noon time is not the right time to take side shots of black on black on black vehicles.
    The truck looks pretty nice as it is too.
  19. Saxon
    Saxon
    from MN
    I did a 3 inch drop axle up front with stock spring. 2 inch reverse eye posie in rear with longer shackles. Kept a 20 degree angle to the shackles. I think 30 is stock.
    Nice truck you have there. I have replaced the fenders on the front of my truck and I'll looking for some good steel fenders for the rear. These pictures are with the old front fenders.
  20. brandonwillis
    brandonwillis
    from Tucson AZ
    all you need to do is lower the back 2 or 3 inches. almost level the truck out but not quite. Its to stink bug right now
  21. Bingo...
    I think to my eye, 2" down in back and maybe an additional 1" down in front would be perfect...the only thing that jumps out at me is the rear wheel opening. It really stands out since the tire so closely matches the radius diameter. I think the 2" here would make a big difference.
    Having said that, if it effects the drivability enough to make you want to drive something else because of the impracticality of it. leave it as is. It really looks great, but fresh eyes can always find something...
    Todd
  22. It looks good to me , but I like to haul **** in my trucks.
  23. Strange Agent
    Strange Agent
    I'd go down a couple inches in the rear. I think the front is spot-on.
  24. flynbrian48
    flynbrian48
    Do you like it there? That's what counts. My '51 wagon looks good, but it's really to low for towing, just like your concern. First off, it has to be functional...
  25. Hazman1929
    Hazman1929
    from Kemah, TX
    I like the way it looks like that especially if used for towing. The big/little tire combo flows good.
  26. fab32
    fab32
    One thing, and I"m surprised PasadenaHotRod didn't advise, is don't do anything until you've got a few hundred miles on it. My experience is the springs will settle 1" to 2" after they have a chance "work". After that you can make a smart decision on any alterations.
    Frank
  27. Winged Avenger II
    Winged Avenger II
    from Wisconsin
    nice truck. personally, i would rake it. front low, *** in the air.
  28. Dan Hay
    Dan Hay
    Dropped axle! Front needs to come down a bunch. Also, a front bumper would help.
  29. Its a work truck. The stance is perfect since you are actually DRIVING and TOWING with it.
  30. holeshot
    holeshot
    from Waxahachie
    hey BBOB... man i think its perfect! nice small rake, and plenty of room for load.you have done a wonderful creation on that old boy! but hell I LOVE OLD SCHOOL! can U dig it? i would kill for that truck hummm, just where do u LIVE? HA!...POP
