SBC 265 & 6-71 Blower
Discussion in 'The Hokey Ass Message Board' started by rhpope, Oct 23, 2009.
  1. rhpope
    rhpope
    Has anyone ever put a 6-71 blower on a SBC 265? If so what sort of underdrive ratio did you use to get somewhere in the range of 6-8 psi of boost?
  2. Herdez
    Herdez
    Well, I dont have a direct answer to your question but I'm sure you can find more info under the topic third gen camaro supercharged 305 tpi motors. 305s and 265s share the same bore. Think of a 305 as a stroker 265 lol!
  3. squirrel
    my 6-71 at 1:1 on a 454 makes 7 psi....i think you'd be happier with a 4-71
  4. Tudor
    Tudor
    from GA
    Wouldn't it would depend on the compression ratio? Look on www.blowerdriveservice.com they have the charts to get you close. You'll have to extrapolate a litte. I have a 283 with a 471 and 76CC heads on it. It make 8 -10 psi at wot and it is driven 1:1
  5. dbradley
    dbradley
    I agree with Squirrel, 'cept a 4-71 manifold is VERY hard to find. Been looking for 2 of them for a while. And, I know you can put a plate on a 6 manifold but it just looks wrong......
  6. onlychevrolets
    onlychevrolets
    Once again...Squirrel is correct...that small inch engine doesn't need a 6-71.. you have to turn it so slow...a 4-71 like TUDOR is running will do you just fine.
  7. rhpope
    rhpope
    I should add that this is a small bore 6-71. The problem with all the drive ratio boost charts is that none of them agree between others. I have looked at several different websites and none of them agree.
  8. alleyoop392
    alleyoop392
    I run a 671 on a 276 ci flathead with 7-1 heads. I run 20% underdriven. At 5grand it is showing 15lbs on the gage. That is not true cyl. pressure, it is plenum pressure not making it in the intake ports. Plenty for a 3 main motor.
    Just run your clearances a little loose on the rotor setup.
    I have 35K on the setup with no problems.
  9. squirrel
    have you looked into welding a plate on top of an old 4bbl intake?
  10. onlychevrolets
    onlychevrolets
    That will work IF the carburetor mounting surface is parallel to the crank shaft or the belt will run off.
  11. squirrel
    that's why they make mills?
  12. the shadow
    the shadow
    If you want a intake like the one mentioned (4 barrel to blower) PM me I know were one is, I can get you a price and a pic if you want. located in PA
    Paul
