Positraction question
Discussion in 'The Hokey Ass Message Board' started by cktasto, Oct 26, 2009.
  1. cktasto
    cktasto
    I did a search and gave up after the 7th page...I have an Olds rear end (72 Cutlass?) and I've got the car up on jacks. When I turn one wheel (left rear) the other turns in the opposite direction. Is this a limited slip differential?
    I've got a bead on a chevy 12 bolt out of a camaro for good price but if I dont need it....:)
    thanks
    Charlie
  2. MarkzRodz
    MarkzRodz
    No,,it's an "Open" rear end,,a one wheel peel. If they both turn in the same direction then it's a posi or locker. That particular rear end should be an 8.2 but because of the year it may be an 8.5. Either way they had lighter duty parts than the Chevy did. The Camaro 12 bolt (if it is) will be a leaf spring rear where the Gutlass will be a coil like in the same year Chevelle.
  3. hotrod-Linkin
    hotrod-Linkin
    they should both go the same direction if posi
  4. cktasto
    cktasto
    thanks guys!
  5. SquigMachine
    SquigMachine
    thats weird my trucks 12 bolt when in the air spins one tire one way an the other in the opposite direction....but there are 2 solid blacklines coming out of my garage and going up my street alittle bit
    weird
  6. cktasto
    cktasto
    DUDE! you had to throw a wrench into the works!
  7. scottybaccus
    scottybaccus
    LOL, an open diff can still send power to both wheels as long as they both have traction, but if one comes loose, all the power goes up in smoke and the wheel with traction is worthless.
  8. SquigMachine
    SquigMachine
    its weird mine does that... but when i popped the cover it didnt look like a peg legger
